Special Thanks to Nori-bilt of SA-Tx and T1 for Pb
Old May 20, 2011 | 10:05 PM
JJsMotorsports's Avatar
Default Special Thanks to Nori-bilt of SA-Tx and T1 for Pb
Well guys my clutch blew in vegas and my car sucked Well got back home placed new disks' in clutch today and went to TNT at local track. I went 9.08 off the trailer.
http://www.youtube.com/watch?v=0D1IZPVIIgA
Then i played with my boost and went back out an hour later and ran a 9.06
http://www.youtube.com/watch?v=gMW2O_aG4aM
Again Special Thanks to Nori-bilt(SA-TX) for all the custom Fabrication and hell i put you guys thru!
And T1 for countless help and suggestions and madness i talk with Tony! Your Tunning is top notch Thanks Dogg I'll be in soon to upgrade my Manifold to Kinsler! I'm a half second from YOU!
Old May 20, 2011 | 10:19 PM
htx_jr.95eg's Avatar
Default Re: Special Thanks to Nori-bilt of SA-Tx and T1 for Pb
wow car is moving max.... congrats, I need to get out soon...
Old May 20, 2011 | 10:21 PM
I see you finally decided to drive that car.....
Old May 20, 2011 | 10:41 PM
BrownDx's Avatar
Nice work, going fast.
Old May 20, 2011 | 10:42 PM
Zer0_SpeedWorks's Avatar
congrats!
any rundown of the setup?
Old May 20, 2011 | 11:30 PM
22_42r_eg's Avatar
Congrats max... Very much deserved
Old May 21, 2011 | 01:20 AM
ricerEP3's Avatar
car is ****in movin out now. that bitch is quick
Old May 21, 2011 | 02:34 AM
civicguy's Avatar
congrats,btw the way you shift that car is awesome too
Old May 21, 2011 | 03:30 AM
DC5TypeS02's Avatar
How does your short track compare to previous passes? because it looks like you are getting off the line way harder!
Old May 21, 2011 | 04:59 AM
harhoosh's Avatar
Nice runs, good luck on your goal.
Old May 21, 2011 | 05:38 AM
Originally Posted by Zer0_SpeedWorks
congrats!
Its on Motec M800 w/T1 tunning
8 Id 1Ks
Fuel is VpImport
Liberty DB w/bc
BMC intake pro level- for sale-
M&Wpro drag 4
Pro level axles DSS w/spool (sucks when you have to push it)
Fabrication done locally At Nori-bilt
I used to get 1.60s low to 1.58s 60's i play with suspension and now getting low 1.50s
Short track is getting better as i learn my car and putting more wieght in front of tire helps ALOT!
Thanks Guys! 8's is the goal for this year!
Old May 21, 2011 | 05:43 AM
gizzmo222's Avatar
Congrats, car is moving and looks like you are cutting good trees too!!
Old May 21, 2011 | 06:13 AM
harhoosh's Avatar
It's the time to change your signature .
alopez84's Avatar
Good job Max! Good luck this weekend!
Old May 21, 2011 | 06:49 AM
Poootie's Avatar
that thing is movingggggg!!!!
question?.. do you leave it in gear after the pass? (like do you let 4th wind out?)
sounds like you are..
Old May 21, 2011 | 07:26 AM
pellis90's Avatar
Good job, keep up the hard work !!
Old May 21, 2011 | 07:33 AM
i leave it in 4th to help slow down half way on the breaks.......
Old May 21, 2011 | 07:38 AM
gogetta's Avatar
Good Job!!
What gear are you doing your burn out's in???
Old May 21, 2011 | 07:40 AM
Originally Posted by gogetta
Good Job!!
3rd
Old May 21, 2011 | 07:45 AM
gogetta's Avatar
Originally Posted by JJsMotorsports
3rd
Thanks!!
Gonna call you the John Force of import drag racing
Old May 21, 2011 | 07:52 AM
20psimitsu's Avatar
Damnit Boy!!!! Almost there Max
Old May 21, 2011 | 10:08 AM
tony1's Avatar
Almost there! Send me the logs.
Old May 21, 2011 | 10:17 AM
intevic94's Avatar
Congrat Man. Car is moving.
Old May 21, 2011 | 10:54 AM
Poootie's Avatar
so the chute is for show?
Old May 21, 2011 | 11:00 AM
Dragmania's Avatar
your ****ing with me right? Your required to have it period if you mph even once over 150mph. You dont have to use it, but you have to have it. Basically in the event of oh $hit my brakes dont work. nice runs.
