Where did u order your oxygen sensors?
Old May 20, 2011 | 08:40 PM
STREETFIGHTER50's Avatar
Default Where did u order your oxygen sensors?
Looks like I may need a new oxygen sensor on my 1999 Civic VP.
"Catalyst System Efficiency Below Threshold (Bank 1)"
I know OEM is the way to go. Where's the cheapest place to order?
Old May 20, 2011 | 10:03 PM
SJC's Avatar
SJC
Default Re: Where did u order your oxygen sensors?
honda
Old May 21, 2011 | 12:31 AM
SeanK325's Avatar
you can get the NGK (aka NTK) oxygen sensors from amazon.com for cheaper than anywhere I've seen. and it's free shipping, usually. just go on ngk.com and get the correct part number.
fyi, you don't HAVE to go NTK. Bosch makes great O2 sensors as well.
Old May 21, 2011 | 03:27 AM
HondaPartsHero's Avatar
Technical Hero
X2 except I get the denso ones. They pretty much are identical to the NGK's. Very quality and usually a bit cheaper than NGK. Here's a link to your O2
http://www.amazon.com/Denso-234-4099...ar=1&carId=007
Old May 21, 2011 | 08:00 AM
HondaPartsHero is this one u linked the correct one i need? My car is a 99 DX-VP. Code says "bank 1"
http://www.amazon.com/gp/aw/d/B000C5...ar=1&carId=007
Old May 21, 2011 | 11:24 AM
Local Autozone has the Bosch sensors within one day of ordering. $66 & a 1 year replacement warranty. What yall think of that?
Old May 21, 2011 | 11:51 AM
SeanK325's Avatar
Why spend over $70 with tax? Here is the NGK one that I mentioned for $39.
http://www.amazon.com/NGK-24542-Oxyg...1999&carId=066
NGK Part Number 24542.
Old May 21, 2011 | 01:01 PM
Hey Sean I just checked that one u posted. On the drop down list for a DX trim & it says "does not fit your vehicle"??? Did you purchase this exact one for your car?
Old May 21, 2011 | 01:13 PM
SeanK325's Avatar
That's the one on the NGK website for a 99 Civic VP and DX for the pre-cat sensor. The post-cat sensor is the same on an automatic DX, but different on a manual trans. Check for yourself on NGK.com.
Old May 21, 2011 | 01:26 PM
Allright cool! Thanks! I will order ASAP. I got that Amazon acct that gives me free 2 day shipping!
Old May 21, 2011 | 01:40 PM
Linked's Avatar
amazon.com has the denso o2 sensor for 40$ i've been using one for over a year now and i get 35+ mpg highway all the time and no CEL
SeanK325's Avatar
I got Amazon Prime for free because I'm a student. It's awesome.
Old May 21, 2011 | 01:41 PM
SeanK325's Avatar
Can't go wrong with Denso or NTK.
Old May 21, 2011 | 01:43 PM
fleabag's Avatar
How fast do you cruise on the highway? 35mpg highway seems kinda low actually for a M/T Civic EX or not.. your car needs a tuneup.
Old May 21, 2011 | 01:46 PM
Linked's Avatar
the car has gotten a tuneup, maybe time for one at the end of the summer
new plugs, ngk wires, purolator filter, purolator fuel filter (it needs changing about now though and is due for an oil change now
my brochure says about 36mpg highway for MT ex's
i have an auto converted EX and do about 75mph on road trips
Old May 21, 2011 | 02:05 PM
98civdx's Avatar
Master Detailer
I have had my NGK for a little over 3 years now. With no issues.
Old May 21, 2011 | 03:14 PM
fleabag's Avatar
Did you adjust the valve lash? Did you replace the PCV valve? Have you replaced the vacuum hoses? Have you cleaned out the throttle body and IACV? My fuel economy dropped by 5mpg and the performance dropped when the PCV valve in my civic finally clogged up and that was just from a $5 part! Have you redone your electrical grounds? While it's true that your vehicle is rated at 35mpg on the highway, in practice the fuel economy is generally significantly higher when cruising. My Civic is rated at 37mpg on the highway but I get 50mpg when cruising on the highway at 55mph.. Most numbers I hear for the civic usually have highway MPG in the 40s..
Old May 21, 2011 | 03:25 PM
Linked's Avatar
i do have to adjust the valve lash cause i havent checked it yet, i checked the pcv valve and it still has the rattle (pretty sure someones gonna disprove me for that), vacuum hoses havent been replace, but any vacuum leaks would typically cause a weird idle right?
and i do have sort of a sticky pedal, i cleaned the iacv before but not the TB thoroughly enough
and where are the grounds located? i only know of the thermostat ground, valve cover ground, transmission ground
Old May 21, 2011 | 03:44 PM
cheggie's Avatar
Streetfighter50, you got a code P0420 right? You need to check out diagnosis for catalytic converters. The O2 sensors on 96 and newer usually set their own problem codes, and they seem to last longer than the OBD0. I don't replace one unless it has set a code for the oxygen sensors. Catalyst efficiency is referring to the catalytic converter. You might just try resetting it first before digging into a possible converter issue.
Old May 21, 2011 | 07:19 PM
Atomic1's Avatar
For my 2000 civic, The NTK Primary O2 sensor i ordered from www.sparkplugs.com only lasted 5000 miles before it died.
Then I bought a bosch from autozone and it's been fine so far 7000 mi and counting.
I'm not convinced NTK is the way to go. Maybe i got a dud.
Old May 21, 2011 | 07:52 PM
lilz24's Avatar
autotechwarehouse.com
Old May 21, 2011 | 08:22 PM
alphalanos's Avatar
got a Bosch for $80 something from some random parts site. Been good for 40k+
Old May 21, 2011 | 09:16 PM
fleabag's Avatar
I don't recommend bosch for non european cars.. Stick with OEM or OEM branded parts.. So if it specifies Denso, use denso.. Bosch, use Bosch.. Most cases I've seen cars running bad or getting poor gas mileage are usually those running the wrong parts. Japanese cars don't run well with Bosch. If you want guaranteed reliability and the car running exactly how Honda intended, stick with OEM parts.. OEM parts doesn't necessarily mean buying from the dealership.
Old May 21, 2011 | 10:00 PM
98civdx's Avatar
Master Detailer
^Just to add on a little to what he said. My friend bought a Bosch, and the car continued to run like *** and throw a CEL for the primary O2. He exchanged it, and it continued. Before we went back, we decided to pull mine( car wasn't being driven, didn't and didn't need it.) When we did that, the car ran fine.
If OEM says NGK/NTK that's what you should use.
Definitely don't buy it from Honda, you'll get rapped.
Old May 22, 2011 | 09:05 AM
Atomic1's Avatar
I am giving you a data point that the Bosch is running fine and my mileage is at 32MPG on the highway. I tried the NTK sensor and it failed on me, so take it for what it's worth.
I am not posting what my friends experienced.
And I'm one who usually always buys Honda parts.
