Is touching a clutch with fingers bad?
Old Sep 30, 2002 | 11:04 AM
KURRRRWA
Guest
Posts: n/a
Default Is touching a clutch with fingers bad?
Hey, since my clutch is starting to slip (31,000) I have been looking for new clutch kits. A friend of mine wants to sell me a Spoon clutch with clutch cover for $300 brand new, but when I was looking at it yesterday, I held it by the actual pad part of the clutch (the part that grabs). He then told me it was bad to touch it like that, because the oils come off on your fingers, and the grease from your fingers gets on the clutch.
Is this so? Is the clutch affected or can I still use it?
Is $300 a good price for a Spoon Sports clutch kit?
Thanks
Old Sep 30, 2002 | 11:10 AM
sackdz's Avatar
Default Re: Is touching a clutch with fingers bad? (SD99Si)
LOL, you can still use it. Wouldn't be a bad idea to clean the surface though.
Old Sep 30, 2002 | 11:40 AM
GB's Avatar
GB
Don't let him freak you out...just wipe it off with a rag.
I remember reading the Mercedes maintenance manual for my parents 1981 300 turbodiesel. The Germans were soooo **** retentive about maintenance -- they said to ONLY use a muslin or other NON-LINT producing cloth to wipe the dipstick when checking oil.
The theory was that if you used a paper towel, some lint might come off and contaminate the oil. Geez...how retarded is that? I'm amazed they didn't say not to drive in the sun because it fades the paint.
Old Sep 30, 2002 | 03:07 PM
Jared's Avatar
Default Re: Is touching a clutch with fingers bad? (GB)
wipe it off with a rag, but dont use any cleaners what so ever, clutch disks are like sponges with stuff like that and they'll never stop slipping afterwards.
Old Sep 30, 2002 | 03:51 PM
-Whitey-'s Avatar
Default Re: Is touching a clutch with fingers bad? (Jared)
good to know, you learn somthing everyday on h-t
Old Sep 30, 2002 | 06:55 PM
KURRRRWA
Guest
Posts: n/a
Default Re: Is touching a clutch with fingers bad? (one_honda)
Thanks, guys. Also, what is the avg. price for a Spoon clutch w/ clutch cover?
Old Sep 30, 2002 | 06:58 PM
vtec.dc2's Avatar
$300 is good for any street disk clutch kit
Old Sep 30, 2002 | 06:59 PM
smokin rubber's Avatar
You use brake parts cleaner to clean the friction surface of both the disc and flywheel. Just like a brake rotor and pad.
Old Sep 30, 2002 | 08:11 PM
lazerus's Avatar
Default Re: Is touching a clutch with fingers bad? (smokin rubber)
they would rename brake cleaner to "all purpose Dirt and grime remover"
I love that stuff!!!
Old Sep 30, 2002 | 08:15 PM
tinkerbell's Avatar
Default Re: Is touching a clutch with fingers bad? (lazerus)
i think it is carconogenic (sp?)
t..
Old Sep 30, 2002 | 08:17 PM
tinkerbell's Avatar
Default Re: Is touching a clutch with fingers bad? (tinkerbell)
correction:
carcinogenic: n. A cancer-causing substance or agent.
t..
Old Sep 30, 2002 | 08:21 PM
tinkerbell's Avatar
check out this PDF from Minnesota Pollution Control Agency titled:
Selecting and Managing Brake and Carburetor Cleaners
http://www.pca.state.mn.us/waste/pubs/4_10.pdf
hope this helps!!!!!
t..
Old Sep 30, 2002 | 08:42 PM
EpDarks's Avatar
Just curious... But how is your clutch slipping already at 31k miles?
I hope mine doesn't suffer the same fate...
EpDarks- who is painfully awating that 30k mark.
Old Oct 1, 2002 | 04:36 AM
Plan B's Avatar
Default Re: Is touching a clutch with fingers bad? (EpDarks)
Isn't the spoon clutch just a repackaged type r clutch. Therefor it will more than likely slip when any real horsepower is put on it?
fkneh
Aug 30, 2005 05:48 PM
taffetawhitegsr
Aug 24, 2004 06:16 PM
