wont stay running got fuel got spark
Old May 20, 2011 | 02:11 PM
mixedboydriver's Avatar
Icon3 wont stay running got fuel got spark
Have a 92 accord recently ran out of gas and a week later bogged out while driving and no more driving . It would still start but as soon as I put it in drive or reverse and hit the gas it would cut off . So I had the fuel filter changed the tps changed and then another throttle body complete cleaned the fuel injectors and the egr valve . It will start and is a lot better than before sound wise but just won't stay on now . Please help I checked the codes with the 2 wire connector near ecu(ecm) and got a 0 which says ecu . From there I looked at a site and it fits into a possibility of a bad ground for the ecu besides that I think its possible its the iacv or the fitv or a vacuum leak. What's your take on this please help I need to get it running and staying running and driving . in another forum someone said if the ignition switch assembly is a possibility and that if the check engine light did not stay on when it stalled out that that was likely it. when i started it it surged to about 2500 rpms and then bogged down to 500 or 600 rpms and cut out. please help
B_Swapped93
Mar 8, 2013 09:08 AM
ascarberry
Mar 4, 2011 02:34 PM
1sikhatch
Honda Civic (2001 - 2005)
24
Mar 21, 2010 02:49 PM
budget_hatch
May 19, 2008 11:45 AM
ewing86
18
Oct 26, 2004 07:53 PM
