What type of injectors for turbo???
What type should i get? Peak and hold-- or Saturated?? I used to search function.. didn't help tho- What are the differences between the two?
Depends on what car you've got. If you've got a 88-91 CRX or a 92-96 Prelude you should get Peak and Hold injectors. If you have any other car other than older Hondas (Pre-88) then you should get Saturated. The difference is how many ohms the injectors run at, which is what the ECU uses to tell the injectors when to spray.
http://www.rceng.com for more info.
[Modified by Turbo Lude SH, 12:05 PM 9/30/2002]
[Modified by Turbo Lude SH, 12:06 PM 9/30/2002]
RacerBoy
Jun 15, 2003 09:04 PM
