Whats The Easiest Way To Install a Clutch Master Cylinder On a 93 si d16?
Old May 20, 2011 | 10:33 AM
Nickhead's Avatar
Default Whats The Easiest Way To Install a Clutch Master Cylinder On a 93 si d16?
I just recently had my clutch go to the floor and lost all pressure, but still had all my fluid. So I replaced the slave cylinder and bled it for 1 hr, but it is still too soft to engage the clutch. So I just picked up my master cylinder, and im going to change it out this weekend, but i heard that they can be a pain to bleed properly. Does anyone have any tips on how to bench bleed, and any tricks to get the old one out without any headaches?
Old May 20, 2011 | 02:31 PM
donut.'s Avatar
Default Re: Whats The Easiest Way To Install a Clutch Master Cylinder On a 93 si d16?
There's only 2 bolts, a tube, and a hardline to remove. What kind of tricks can there be. A sawzall maybe?
Old May 20, 2011 | 03:07 PM
grumblemarc's Avatar
The Grumpiest
I was thinking maybe it was a trick question.
Old May 20, 2011 | 03:20 PM
hondatuner34602's Avatar
Post Re: Whats The Easiest Way To Install a Clutch Master Cylinder On a 93 si d16?
the quick way to do this is remove the 12mm flare nut line from the slave cylinder dont worry if u bend the line cuz they are flexible and remove the two mounting bolts i think they r 12mm or 10 mm. once that is done swap out the old one for the new and bleed the air from the slave cylinder
dtran002
Jun 12, 2013 10:12 AM
Maple50175
Honda Civic (2001 - 2005)
Nov 2, 2009 12:38 AM
Christopherian1982
May 25, 2009 08:10 PM
Hard2Find
14
Aug 9, 2005 08:32 AM
xprohx
Nov 30, 2004 03:43 PM
