98 spec HID bulb change
Do I need to remove the headlight to change the HID bulb?
I looked under the hood and it seems pretty jammed where the balast is.
Anyone changed the bulb before?
Cheers.
Cheers.
I believe you can get it out without removing the headlight, You have to unscrew and unbolt the ballast and sits behind there
You have to buy a torx either t-20 or t25 to remove the black metal box behind the balast. There are also four phillips screws and two ten bolts on the black box. After that the entire box and frame support should come off, giving you access to the ballast. Twist the ballast counter clockwise and this will leave the bulb exposed, being held in by just the clip.
Installation is the reverse. Good luck.
Yes, from what I remember when replacing both D2S bulbs, I had to remove the entire headlight assembly in order to get to the ballasts. Before I had to do that, I had to remove the grill and bumper. The headlamps are fastened to the front bumper support. There's probably a shortcut to removing the headlamps in order to get to the ballasts but I didn't want to mess anything up.
I changed out the bulbs.
Must take off the bumper in order to take the headlights out.
Its so jammed near the ballast when the headlight is on the car, I dont think its possible to change the bulb without taking the headlight off the car.
thecat746
Honda Civic (2001 - 2005)
Jan 23, 2013 11:36 PM
powersteer
Jul 25, 2006 07:42 AM
ef_you_again
Apr 10, 2005 12:57 PM
