Sohc I-beam, Holset, Autometer, BFG, EG, Fast Turbo, Alarm, Mounts, RyWire
Old May 20, 2011 | 06:56 AM
ReDemoN's Avatar
DixielandImports Please
Default Sohc I-beam, Holset, Autometer, BFG, EG, Fast Turbo, Alarm, Mounts, RyWire
Ok I need to get rid of this stuff.
Im open to reasonable offers.
Just send me a PM with an offer the worst I can say is no.
If you are looking for something I might just have it, so ask.
These prices include shipping unless noted otherwise.
Holset H1E Turbo
I dont really know the specs of it honestly
Worked great at 25lbs on the single cam
Has only 500 miles on it.
Will come with the fitting to put a -3an oil line on it and the custom made oil return. Also the downpipe flange.
350 Shipped
Sohc I-beam rods
I did spin a bearing on one of them, being the reason they are so cheap
They do have the 3/8 ARP rod bolts in great shape.
100 Shipped for the set of 4
Autometer Cobalt series Electronic Boost gauge
Glows blue
Has the map sensor with it for a true boost reading.
Very nice unit, goes to 30psi
115 Shipped
Fast Turbo Black Vaccum block
Has a few scratches on it
30 Shipped
205-50-14 BFG Drag Radials
Have around 500 Miles on them
Only three passes at the track
Still have alot of meat left on them
135 SHipped for both
RY-Wire OBD2B to ODB1 ecu conversion harness
Brand new never been used
75 SHipped
SOHC 10mm Ebay Spark Plug Wires
Black in color
Worked great at 400whp
35 Shipped
Innovative EG Rear mount and Trans mount
Has the Race insert Urethane in it
50 Shipped each
This is a fuel line fitting
It fit into my GE fuel rail and has a -6an fitting on the other side.
I think the Fuel rail side is a -10an
12 Shipped
I have two older uncut Ls valve covers, One is Stock black the other is painted red
35 Shipped each
92-95 Civic Tilt Column
Will be just the column no steering wheel or switches (unless you want those things Extra money)
50 Shipped
92-95 Civic headlights
Only tab that is broke is the drivers one where the corner light screws down
40 Shipped for both
92-95 Drivers Airbags
I have two grays and one tan
All the plugs are intact
20 Shipped each
92-95 Civic Ex Air Cleaner setup with Resonator
All tabs are in good shape will include hose.
45 Shipped
92-95 Civic EX Sunroof Assy.
In good shape and works
75 plus actual shipping.
Its gonna be a bitch to package up also.
I have a shelf full of mounts.
They are pretty much all single 92-95 mounts manual you stuff like that
They will be 15 shipped each doesnt matter which ones you want
Vision FPR. This is an Ebay FPR. Comes with the adapter to install on a Honda fuel rail.
Will include a liquid filled gauge.
45 Shipped
Prestige Alarm system.
This is just a basic lock/unlock alarm system
Has one remote
Not sure on the model number or anything
Has the horn
50 Shipped
B series Shift Linkage
Stock shifter, bushings look good
65 Shipped
C/C Stage 4 Sprung Clutch Disc
Has about 500 Miles on it (just broke in)
65 Shipped
Old May 20, 2011 | 10:13 AM
ReDemoN's Avatar
Default Re: Sohc I-beam, Holset, Autometer, BFG, EG, Fast Turbo, Alarm, Mounts, RyWire
Bump!!!
Old May 24, 2011 | 10:24 AM
ReDemoN's Avatar
BUMP!!!!
Old May 27, 2011 | 01:48 PM
ReDemoN's Avatar
Bump!!!
Old May 31, 2011 | 03:41 AM
ReDemoN's Avatar
BUMP!!!
jiggs
Jun 12, 2007 11:30 AM
FastAzzCivic
Sep 24, 2006 02:58 PM
Tomek
Apr 19, 2004 10:29 AM
