motor mount studs too short on drivers side; B20 swap with avid mounts
So I have a jdm b20 on Avid mounts in my 98 civic DX, the post on the driver's side has the two studs that contect to the mount but the two studs are too short. here is a picture
Is there a longer version of this stud I should be using? the post and studs are from an SI, as the one that came on the B20 was all funky and whatnot. Any help at all would be appriciated.
measure the length you need and go to the hardware store and by grade 8 bolts and washers, use lock-tite. i had to do the same thing with my avid mounts
crxaruba
Feb 18, 2010 06:32 PM
