Air horn won't work anymore.......HELP quick
Old Sep 30, 2002 | 10:45 AM
Dan GSR's Avatar
Default Air horn won't work anymore.......HELP quick
Well it rained pretty hard....and after that my air horn wouldn't work
I took apart the relay...and found a lot of dirt in it....so I replaced the relay....still nothing
I tested the pump......hook it up directly to battery....it works
I'm getting 12v reading at the connections of the pump when i press the horn
What else should I check for? What can be wrong??
Old Sep 30, 2002 | 12:14 PM
TheIntegraGuy's Avatar
Default Re: Air horn won't work anymore.......HELP quick (Dan GSR)
try using another relay or check the fuse to the horn....
Default Re: Air horn won't work anymore.......HELP quick (SiDESLiDE240)
to the car horn fuse that is....my bad
Old Sep 30, 2002 | 05:30 PM
Dan GSR's Avatar
I figured it out....somehow my ground went bad.....thanks guys
[Modified by Dan GSR, 9:31 PM 9/30/2002]
choua01
Honda Civic (2006 - 2015)
Apr 25, 2012 10:13 PM
purple
Honda Civic (2001 - 2005)
Aug 16, 2011 06:08 PM
rleonekc
Mar 5, 2008 06:39 AM
JerseyJohnny
Apr 16, 2007 04:51 PM
JBirch_97Prelude
Apr 10, 2006 04:33 PM
