running 90 ls brakes all around on 89 CRX SI, 91 master cylinder ok?
Old Sep 30, 2002 | 10:42 AM
spettinger's Avatar
Default running 90 ls brakes all around on 89 CRX SI, 91 master cylinder ok?
have an 89 CRX SI with 90 teg ls brakes all around, would the 91 CRX SI master cylinder and proportioning valve be ok to run the brakes? isn't it the same as the 90 teg ls master cylinder?? thanks.
Old Sep 30, 2002 | 10:58 AM
Aron Parsons's Avatar
Default Re: running 90 ls brakes all around on 89 CRX SI, 91 master cylinder ok? (wreckedhatch)
that MC is acceptable, but if you're going to put that much into your braking system, spend another $40 and get the larger MC. to finish it off, i'd recommend stainless lines too, those only add to pedal feel though (very good for auto-x/road racing).
Old Sep 30, 2002 | 11:07 AM
spettinger's Avatar
Default Re: running 90 ls brakes all around on 89 CRX SI, 91 master cylinder ok? (OvERaCiD)
yes, i am doing the lines as well, by the larger master cylinder, you mean the integra unit?
Old Sep 30, 2002 | 01:27 PM
89civic1.8T's Avatar
I put a 90 teg MC and booster on my car. The MC it's self won't fit with out the booster.
Old Oct 1, 2002 | 08:30 AM
spettinger's Avatar
Default Re: running 90 ls brakes all around on 89 CRX SI, 91 master cylinder ok? (89civic1.8T)
you can run an 89 booster with a 91 master cylinder, correct?
persianp
Jun 4, 2008 02:39 PM
ZcivicC
Mar 28, 2005 03:26 PM
RAWbertCuBus
Oct 19, 2002 08:00 PM
12345
Oct 7, 2002 11:14 PM
