Suspension & Brakes Theory, alignment, spring rates....
LCA Bushings (pictures)
Old May 19, 2011 | 09:17 PM
Dontoh's Avatar
Default LCA Bushings (pictures)
My drivers side lca bushing is completely wasted.. However, my funds are tight and I need to get the car running first, lcas aren't really a concern. how important is the bushing, and can run it for a bit before replacing the bushings? id like to do them all at once..
its this one
Old May 19, 2011 | 10:11 PM
RagnarX's Avatar
Default Re: LCA Bushings (pictures)
It'll make a lot of noise/clunk if you leave it too long, but it can wait imo. Within reason.
Old May 19, 2011 | 10:14 PM
98civdx's Avatar
Master Detailer
You can, if you wanted to. My friend just replaced his bushings, which were so shot we pushed the bushing out of the arm by hand. The car wasn't behaving anywhere near the way it should.
Are you on OEM arms? How tight is tight?
You could always just find some used EG/DC arms and throw them in. Shouldn't cost much more then 50-60 for both. I sold mine for 25. Just to give an idea for price.
Old May 20, 2011 | 02:17 AM
Libertariat's Avatar
Ek Forever y0!
Any bushing that is ruined needs to really be replaced. It can dramatically effect handling, alignment, and therefore tire wear.
Old May 20, 2011 | 03:28 AM
g230sport's Avatar
if its just a DD type car, leave it for a little while, youll never get the alignment dead on, and it could make some noise.
but if your going to autox the car or track it, it should be taken care of ASAP!
Old May 20, 2011 | 03:49 AM
Ek Forever y0!
What are you smoking? A ruined bushing will make the car nearly undrivable and will shred his tires. Why not get a replacement bushing from autozone for cheap and at least have a plain rubber bushing in there?
Or better year, get an NEW oem arm from the dealership for the ~$64 they cost.
The only reason the alignment will never be spot on is because of the bushing. Barring anything else replacing that bushing will keep his alignment in spec.
PatrickGSR94
Suspension & Brakes
44
Jun 13, 2013 03:28 PM
RanCRX
10
Oct 7, 2012 09:13 PM
thenext
Oct 18, 2011 02:12 PM
beanbag
Suspension & Brakes
Aug 14, 2007 11:10 AM
opeth13
Suspension & Brakes
Feb 3, 2006 12:10 AM
