Cometic LS/CRVTEC headgasket confusion.
Old Sep 30, 2002 | 10:40 AM
boomslang's Avatar
Default Cometic LS/CRVTEC headgasket confusion.
Okay, so my 85mm Cometic gasket came in the mail finally. I compared it to the stock B20 headgasket I have laying around. The Cometic doesn't line up worth a crap. The Cometic gasket also has the oil supply hole in it that is used only for vtec blocks.
The Cometic lines up perfectly with every passage on my B16 head though.
Could this be a reason so many people have had Cometic gasket sealing problems on frank motors? Essentially, Cometic sent me a bored B16 gasket, not a bored B20 gasket like I need.
Old Sep 30, 2002 | 02:49 PM
CHEETAH's Avatar
Default Re: Cometic LS/CRVTEC headgasket confusion. (Inlinefour)
they just sent you worng gasket thas all ... I have both types when I order my cometic. Send it back without opening and get the 85mm vtec one.
Greg
Old Sep 30, 2002 | 04:31 PM
Quick 200k Mile Motor's Avatar
Default Re: Cometic LS/CRVTEC headgasket confusion. (CHEETAH)
Greg
you mean "get the 85mm non-vtec one."
Old Sep 30, 2002 | 04:38 PM
boomslang's Avatar
Default Re: Cometic LS/CRVTEC headgasket confusion. (Quick 200k Mile Motor)
Considering they build the gaskets, you'd think they'd know what works.
Old Sep 30, 2002 | 04:51 PM
sgT's Avatar
sgT
As I said in your other post, i have never gotten the wrong gasket from cometic
thus far. But if you are having so many problems, you should just use a crv gasket
from the dealer instead.
Rheg6
20
Sep 16, 2009 07:45 PM
urtz
Dec 13, 2006 03:06 PM
RTW DC2R
Jul 16, 2004 07:22 AM
NightHawkC5
Feb 24, 2003 09:02 PM
boomslang
Sep 30, 2002 04:37 PM
