4th gen prelude turbo build part out
95 black honda prelude full part out. Everything is for sale, if you do not see something you need ask and I probably have it. I have many factory pieces and extra parts. If interested call Anthony at 720-231-6720
Helms manual - Makes offer
ENGINE/TRANSMISSION:
hondata s300 with boost control and 4bar map sensor p72 ecu - sold
rc750 cc injectors - sold
walboro 255 intank fuel pump - sold
h22a4 55mm main darton sleeved block bored .40 over with balance shaft block off includes arp mains and heads, water pump, oil pump- $1250
h23 crower billet rods - $500
h22 cp +40 pistons - sold
h23 balanced crank with balance crank pulley - sold
turbonetics t3/t04e turbo - sold
Aluminum intercooler piping with all ends beaded and silicon couplers - sold
24x12x3 intercooler - $150
H23 bdl 70mm throttle body w/ port matched intake manifold - $150
2.5" down pipe into 3" s/s cat to muffler exhaust with 3" apexi muffler & 3" cat - $500
H23 drag log manifold - sold
innovative mounts poly motor mounts - $200
msd sci ignition box and coil - sold
act 6 puck sprung clutch with extreme pressure plate - $300
act street light flywheel turned once - $100
golden eagle scatter shield - $200
Aem fpr - sold
Aem fuel rail w/fuel pressure gauge - $75
Forbidden motorsports cooling plate - sold
forbidden motorsports short shifter - $150
h23 pnp head - $200
Brand new in box bell housing - $200
any factory part - make offer
SUSPENSION/BRAKING:
tien flex adjustable dampers - $1000
suspension techniques front and rear sway bar with custom rear endlinks - sold
esp traction bar with solid front mount (torque mount) - sold
nuespeed front tower bar - $125
Rota circuit 8 16 x 7 with both bolt patterns with tires - sold
Cusco rear tower bar - $100
em racing c pillar bar - sold
h22 calipers and rotors -- make offer
russel ss braided brake lines -- make offer
any factory part -- make offer
INTERIOR/MONITORING:
aem uego wideband - sold
defi boost/egt/oil pressure with control module with electric sensors - sold
greddy turbo timer - sold
custom wrapped black leather with red stitch shift, e-brake and armrest -- sold
original prelude floor mats -- sold
vtec model subwoofer rear seats -- sold
nrg gen 2 red steering wheel quick disconnect with 2 steering wheels included - $75
EXTERIOR:
JDM **** front lip - sold
modified accord rear lip -- make offer
JDM one piece headlights w/jumper harnesses - sold
JDM amber side marker lights - sold
JDM amber turn signals - sold
window vent visors - sold
Aem fpr - sold
h23 pnp head - $200
SUSPENSION/BRAKING:
EXTERIOR:
Aem fpr - $75
suspension techniques front and rear sway bar with custom rear endlinks - $100
aem uego wideband - $125
JDM one piece headlights w/jumper harnesses - $200
^ Interested.
I dont check HT much, so email is the quickest way to get me. jhart4(at)spsu.edu
^ Interested.
Wanted to add some things that I pulled off this weekend. all stock parts so make me an offer.
tail lights
rear bumper lights
under hood fuse box
hood release
throttle cable no frays is perfect.
vss
rear folding seats full assembly with center (vtec model) black- prefer local pickup
front seats cloth seats black - prefer local pickup
distributor with cap, rotor, and ngk plug wires
starter
alternator has aem pulley silver
power steering pump with aem pulley silver
door panels - prefer local pickup
pulled wire harness a few pigtails have been cut if you need one ask and i will snip it.
again all these parts are make an offer, and i will see if I like them.
also i found a set of silver aem three bolt cam gears will do $100 shipped
tail lights
rear bumper lights
under hood fuse box
hood release
vss
starter
more make offer parts that I recently pulled off
rear speaker covers
front speaker buckets
dip stick tube with dip stick
stock cams (2 sets)
found an extra crank pulley
set of stock h23 injectors
5th gen aluminum oil pan (was drilled and tapped in 2 locations for oil return)
power steering and alternator brackets
Will add more when i pull more
rear speaker covers
stock cams (2 sets)
dep22build
Jan 25, 2010 07:22 AM
92-01 Prelude h22 and h23 parts injectors crank block head cam gears intake manifold thermostat wate
92hondalude
Jun 8, 2007 05:47 PM
flip1199
Apr 16, 2007 07:28 PM
