JDM GSR engine have an oil cooler...?
Old Sep 30, 2002 | 10:34 AM
B19CivicHB's Avatar
Default JDM GSR engine have an oil cooler...?
I noticed that upon reassembly, it doesnt look like my 95 JDM GSR block can have an oil cooler. It isn't on it and there is only a threaded stud for a filter to be screwed on... is this right?
I even bought a cooler in hopes that it had just been lost or something. Anyone know if the JDM blocks were designed with stock oil coolers?
Thanks!
-Nick-
Old Sep 30, 2002 | 11:56 AM
kinesistech's Avatar
Default Re: JDM GSR engine have an oil cooler...? (B19CivicHB)
I've notice that only the earlier model engines have oil coolers. Later model dohc vtec engines dont have them. I dont know why. If you add teh factory one, you need teh water pipe from thermostat to water pump too.
Old Sep 30, 2002 | 01:03 PM
Doctor CorteZ's Avatar
I've never seen a B-series V-tec motor that DIDNT have an oil-cooler
Old Sep 30, 2002 | 01:17 PM
sgT's Avatar
sgT
Default Re: JDM GSR engine have an oil cooler...? (Doctor CorteZ)
no US gsr after 96 should have one.
at least i havent seen one yet nor has there been any mention on any brochures or manuals
the 95 jdm b18c i got had one on it
Old Sep 30, 2002 | 05:26 PM
speedymon's Avatar
Default Re: JDM GSR engine have an oil cooler...? (Sales@ImportBuilders)
So my USDM 96 gsr should have one? Where would it be located?
Old Sep 30, 2002 | 05:29 PM
B19CivicHB's Avatar
Default Re: JDM GSR engine have an oil cooler...? (sgT)
well, my 95 JDM GSR block has what looks to be a threaded male end where you could screw an oil filter on. It doesnt have a hole for the oil cooler screw to be threaded into. Can in unthread the male end that's in the block right now? Ill try to take a pic and post it for easy of explanation.
-Nick-
Old Sep 30, 2002 | 05:30 PM
sgT's Avatar
sgT
If you have no oil cooler and you want to install the factory one.
All you have to do is remove the threaded post for the oil filter which just
unscrews and put in the oil cooler
Old Sep 30, 2002 | 05:43 PM
B19CivicHB's Avatar
where do i get the coolant lines from?
Old Oct 2, 2002 | 07:55 AM
so the 94-95 C1's have NO oil cooler ?
Old Oct 2, 2002 | 08:05 AM
B19CivicHB's Avatar
94-95's DO have a cooler... just not mine for some reason...
Old Oct 2, 2002 | 08:23 AM
hmmm......strange
Old Dec 11, 2004 | 04:46 PM
TurboTeG4's Avatar
Ok but where do you put the Oil Cooler Joint that connects the hose to the left oil cooler port.
http://www.acuraoemparts.com/d...ch=no
Does the obd2 jdm gsr block have the threads to accept the joint?
Looks like I have a bolt where it might be the location of the joint
Modified by TurboTeG4 at 1:56 AM 12/12/2004
Old Dec 13, 2004 | 05:56 PM
TurboTeG4's Avatar
Default Re: JDM GSR engine have an oil cooler...? (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Ok but where do you put the Oil Cooler Joint that connects the hose to the left oil cooler port.
Modified by TurboTeG4 at 1:56 AM 12/12/2004</TD></TR></TABLE>
Old Dec 13, 2004 | 07:33 PM
mmuller's Avatar
Mad Scientist
you need a coolant bypass pipe thas has the nipple for an oil cooler. then you need to tap the block for the ''exit'' to the block
Old Dec 13, 2004 | 07:52 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT &raquo;</TD></TR><TR><TD CLASS="quote">If you have no oil cooler and you want to install the factory one.
unscrews and put in the oil cooler </TD></TR></TABLE>
No, you will also need the tube running from the water pump to the thermostat housing... And the two hoses to connect the oil cooler. THEN you can just thread one on.
Not all of these engines have oil coolers. I don't know the "rules" Honda went by for determining which ones got it and which ones didn't. Even some of the 99 Si's didn't have them, although it seems most did. I also noticed that if you go to Honda, they don't show the 99 Si as EVER having one in the parts catalog.
Old Dec 15, 2004 | 05:22 PM
TurboTeG4's Avatar
Default Re: JDM GSR engine have an oil cooler...? (Hybrid93Eg)
Can you use the stock sandwich adapter in conjunction with a aftermarket cooler?? I dont see why not if the design is the same and just plug the other ends?
Old Dec 16, 2004 | 12:03 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Can you use the stock sandwich adapter in conjunction with a aftermarket cooler?? I dont see why not if the design is the same and just plug the other ends?</TD></TR></TABLE>
What "sandwich" adapter are you talking about?
Old Dec 16, 2004 | 04:53 PM
TurboTeG4's Avatar
the one between the oil filter and the block
Old Dec 16, 2004 | 05:58 PM
ekgcool's Avatar
It is my understanding that only the R motors came with oil coolers. I have worked on a few B series, and the only one to have a cooler is a B18C5 or JDM B18C-R. If you want to use the factory cooler, then you have to get the water pump to T-stat pipe, and if I am not mistake, add a nipple to the block for the coolant feed/return. The R motors have a coolant nipple on the back side where coolant travels. In my opinion, just use an aftermarket cooler and forget about drilling the block or having 80 feet of coolant hose under the hood to reroute the coolant.
Old Dec 16, 2004 | 07:04 PM
mmuller's Avatar
Mad Scientist
Default Re: JDM GSR engine have an oil cooler...? (tekracer)
R's have them
obd1 b18c1's have them
all b16's but obd2 have them
Old Dec 16, 2004 | 09:55 PM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekracer &raquo;</TD></TR><TR><TD CLASS="quote"> The R motors have a coolant nipple on the back side where coolant travels. In my opinion, just use an aftermarket cooler and forget about drilling the block .</TD></TR></TABLE>
On my jdm b18c1 obd2 engine I think theres actually a plug(Bolt)where that nipple supposed to go.
Old Dec 17, 2004 | 12:49 AM
Hybrid96EK's Avatar
Default Re: JDM GSR engine have an oil cooler...? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">R's have them
all b16's but obd2 have them</TD></TR></TABLE>
Not entirely true. My 99 Si had one, and it was OBD-2.
Old Dec 17, 2004 | 06:39 AM
MAV3RiCK478's Avatar
b17s have them hehe
and yes, you can get a sandwich adapter & aftermarket air oil cooler. these actually cool oil more efficiently than the oem oil cooler.
Old Dec 17, 2004 | 08:50 AM
IN VTEC's Avatar
Default Re: JDM GSR engine have an oil cooler...? (MAV3RiCK478)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAV3RiCK478 &raquo;</TD></TR><TR><TD CLASS="quote">b17s have them hehe
and yes, you can get a sandwich adapter & aftermarket air oil cooler. these actually cool oil more efficiently than the oem oil cooler.</TD></TR></TABLE>
You don't get the heat transfer from coolant to oil, which can be both good and bad depending on your climate.
I'm a bit hard pressed to completely eliminate it since the winters get down to 10 to 20 deg F for a month or two...but then again, I hardly ever drive the car during that time too. And, the stock oil cooler is a bit of a restriction...another reason to get rid of it.
Old Dec 17, 2004 | 09:48 AM
Default Re: JDM GSR engine have an oil cooler...? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">You don't get the heat transfer from coolant to oil, which can be both good and bad depending on your climate.
I'm a bit hard pressed to completely eliminate it since the winters get down to 10 to 20 deg F for a month or two...but then again, I hardly ever drive the car during that time too. And, the stock oil cooler is a bit of a restriction...another reason to get rid of it.</TD></TR></TABLE>
yeah it actually gets down to 20 here in norcal so im glad the way the oem cooler works on those days, gets my oil nice and warm a little faster on cold mornings.
