Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
which brand water pump & timng belt?
Old May 19, 2011 | 05:17 AM
Jaydeep's Avatar
Default which brand water pump & timng belt?
I have to change water pump & timing belt on my wife's 03 civic. I know OEM is always good but which other brand is good?
Old May 19, 2011 | 06:28 AM
toyomatt84's Avatar
Sanji
Default Re: which brand water pump & timng belt?
Considering the OEM equipment is fairly cheap, I wouldn't bother with any other brand.
Old May 19, 2011 | 12:17 PM
It Wasn't Me's Avatar
Gates
Old May 19, 2011 | 03:34 PM
MarkM01's Avatar
Any name brand will go 100k miles. I use an a/c delco w/p at 100k, and 200k. Dayco belts, and tensioner.
Old May 19, 2011 | 06:15 PM
Bxjay16's Avatar
http://www.handa-accessories.com/ best oem deals online!
Old May 19, 2011 | 06:42 PM
That's for accessories, the OP is looking for parts.
http://www.hondaautomotiveparts.com/ is highly recommended for OEM parts. (I use somewhat frequently use it)
Might also want to browse the Sponsor Marketplace, as there are OEM parts dealers there too.
Old May 20, 2011 | 05:40 AM
Bxjay16's Avatar
well if you were to look at the side bar and click civic, and then click the year of your car, it says maintenance, you click there and you have a bunch of PARTS for the car, including water pump and timing belts, sooooooo handa dose have PARTS...... check yourself before quoting me!
Old May 20, 2011 | 09:28 AM
Ahhh, there it is! I found it after having to click several different links before finding it.
It would be more helpful to post a link to the Civic Maintenance page, rather than making people search for a little sidebar.
The link you posted: http://www.handa-accessories.com/
The Civic Maintenance page: http://www.handa-accessories.com/civmaint01.html
There are better deals to be found elsewhere on the internet, though.
However! What if he didn't want to buy or otherwise need the belt tensioner or the drive belts? Although most people go ahead and replace them while they're replacing the timing belt (preventive maintenance) it's only recommended to inspect the water pump and belt tensioner. (replace if necessary)
If he were to buy an "all inclusive kit" like that, he'd be overpaying for a kit which includes parts that he doesn't actually need. The better option may be to buy a different kit, or to buy the necessary parts separately.
Moving along now.. ..
Old May 20, 2011 | 10:03 AM
Bxjay16's Avatar
Touche!
scubacamper
Apr 14, 2015 06:04 AM
JDMLyfe89
16
Jan 22, 2013 06:45 AM
91GEDHATCH
16
Dec 22, 2010 07:05 AM
92integraVTECgsr
Jan 30, 2007 01:02 PM
digital sol
May 18, 2005 06:14 AM
