Is 6 tons enough?
I'm about to tear into the front suspension and start pushing out the worn out OEM bushings (primarily the LCA's), and I'd like to get this project done over the weekend. Obviously, the machine shops are closed, but I do have a 6 ton shop press. Do y'all think this will be a strong enough press to push the old bushings out?
Thanks!!!
Thanks!!!
i used a 20 ton for a most of them. on the camber arms i used an arbor press. came out and went in like butter, with the exception of a few that need some coaxing...
solsi2000
Suspension & Brakes
11
Feb 9, 2009 11:26 PM
