full size radiator in a del sol
is it possible? i found that bigger radiator is an extra cushion in case you run low on coolant or have leaks that you did not see
so im trying to see if i can fit a full size dual core radiator in the del sol
for a gsr motor
anyone has pictures of it
how its mounted?
for a gsr motor
how its mounted?
I spoke to a radiator specialist who did not recommend mounting any other radiator other than the one that is already in !! There are twin mounts tho so a full length one should fit !! =S
I've seen it done in a 5th gen civic, shown below, car belongs to B18C5-EH2. I'm pretty sure he had to cut the lower mounts off and weld them in a different spot. Personally I'd just run a Del Sol Vtec dual core rad, even the single core half rad will cool fine.
