problem wih my brakes please help!!
i got a 92 lx. my front drivers brake does not work.marster cylinder is new and change proportioning valve and caliper. and still wont brake. its just the front drivers the passengers work fine. any help? thanks ;(
yea the is fluid going to the caliper cz i beeld the front and the is fluid coming out of both the disc is all rusty thougth could that have something to do with it?
Doubtfull. Did you bleed it right? Start with the rear passenger side, rear driver side, front passenger side, then front drivers side. Bleed the brakes farthest from the resevoir first.
Very well could be. Try bleeding the brakes in the right order that could help. You could spray brake cleaner on your rusted calipers and wire brush clean them and get some of the corrosion off.
