94 accord hesitates shifting into 4th?????
I just purchaced a 94 accod ex auto with a 2.2 vetec. It will shift crisp in all gears except going into 4th? not sure what i should be looking for? also my d4 light is out so i do not know if it is blinking or not. if someone could help that would be great. it will shift if you let out of the trottle. but if you dont it will stay inbetween gears untill you let out of the throttle. please help
Also i unpluged the silinoid on top of the tranny and i did nothing to how it shifted, and i dident know what that one did either. And then i unpluged the one on the bottom and it then made the tranny shift realy bad and dident want to move. not sure if that will help anyone. Thanks
If the light is out, or was removed, you cannot check for TCU codes. Fix the light and check for codes.
http://techauto.awardspace.com/transmission.html
The light can be replaced? i thought it was a led. i will try that tho. also does anyone know what silinoid does what? i cant find anything that tells me what either one does. thanks.
Can't recall exactly which one does what. It's also a combination of which solenoids are on and off that controls the activation of a gear. IIRC the upper pair are for 3rd/4th/lockup. And the lower two are for 1st/2nd/Reverse. But they work together to achieve a given gear selection.
