Final drive
Old Sep 30, 2002 | 09:56 AM
tylerdurden's Avatar
Default Final drive
I'm confused as to how the final drive relates to the individual gear ratios. How is the final drive calculated?
Old Sep 30, 2002 | 11:44 AM
keithv's Avatar
Default Re: Final drive (tylerdurden)
the final drive is a multiplier for your gear ratios.
i am not exactly clear on your question. can you as a more specific question?
also the final drive is not calculated as it is a fixed value depending on the final drive gear ratio.
[Modified by breaka_1_9, 4:36 PM 9/30/2002]
Old Sep 30, 2002 | 11:51 AM
SuperCivic's Avatar
Default Re: Final drive (breaka_1_9)
i've wondered about this too..how do all these gears and ratios relate?
Old Sep 30, 2002 | 01:27 PM
SirYoda's Avatar
the final drive is the last gear (always connected to the output shaft). the bigger this gear is (larger number) enables greater low end acceleration but this hurts top end speed. The smaller this gear is, gives you less acceleration but more top end speed. same goes for individual gears. the trick is to find the (sweet spot) correct ratio so you don't smoke tires or ride the clutch. lots of math involved. and it get expensive quick to change to non-stock gearing.
[Modified by SirYoda, 5:30 PM 9/30/2002]
[Modified by SirYoda, 5:32 PM 9/30/2002]
Old Sep 30, 2002 | 03:27 PM
primoEF's Avatar
Default Re: Final drive (SirYoda)
also gas milage too, bigger final drive = use more gas
Old Sep 30, 2002 | 07:28 PM
Default Re: Final drive (ridge racer 2)
when you say final gear, you aren't talking about 5th. what are you talking about. how many gears are there in the tranny?
Old Oct 1, 2002 | 03:24 AM
keithv's Avatar
there is a gear on the differential referred to as the final drive or the ring gear.
as for how many gears there are in the tranny, there is the mainshaft with gears 3-5 (?) and then you have the countershaft with gears 1-5. then you have the ring gear. so there are certainly alot of gears in the tranny...
Old Oct 1, 2002 | 05:41 AM
SuperCivic's Avatar
gotcha. so the final drive affects ALL the gears..
Midori Green
Apr 30, 2008 09:11 PM
thorshammer56
Honda Motorcycles
Jun 6, 2007 08:05 AM
DARKTEG_
Aug 19, 2006 06:56 AM
L8ApexH22
Jun 29, 2005 07:49 AM
Dorikamu
Jun 20, 2002 11:39 AM
