NJ 1997 Acura Integra LS - 5spd - silver/black - high miles - some body damage
Hi,
I'm selling my 1997 Acura Integra LS.
Specs:
- 247,xxx highway miles - previous owner traveled from NJ to VT often.
- 2nd owner
- vogue silver metallic exterior, black cloth interior
- 5 speed manual transmission
- currently located in northern NJ, outside Manhattan
- clean title: VIN # JH4DC4350VS020296
Condition:
- front bumper and hood were damaged from hitting a deer about 10 years ago. previous owner took car to a bodyshop that did **** poor work - see pictures of hood.
- passenger side door trim bent and partially came off when previous owner rubbed against the garage door frame.
- NYC taxi cab hit my car while parked. It was a low speed impact (another car hit the taxicab, spinning it into my car), but still caused damage. See pictures.
- air conditioner works, but is not very strong. I'm not sure if it's the charge or a weak compressor.
- radio antenna is broken. it did not go down, and an automatic car wash broke it off. I filled it in with putty so water wouldn't leak in.
Maintenance:
(all parts were installed in the past year / 20k miles)
- new front windshield
- new Acura OEM clutch master cylinder installed
- new Acura OEM clutch slave cylinder installed
- new Acura OEM front wheel bolts installed (4 each side, 8 total)
- new Acura OEM wheel lugnuts
- new Acura OEM lower ball joints
- new Acura OEM rubber stabilizer end links
- new Acura OEM front lower control arm bushings
- new Acura OEM front brake rotors and pads
- new Acura OEM gauge cluster lens
- new Acura OEM front hub wheel bearings
- new Acura OEM front brake spash guards
- new Acura OEM cylinder head cover gasket
- new Acura OEM sway bar holder
- new Acura OEM sway bar bushings
- new Acura OEM nuts, bolts, washers, screws for the suspension pieces above
- new Acura OEM air filter
- manual transmission fluid changed with Redline MT-30
- oil changed every 3000-3500 miles at local Acura dealer
Description:
I'm living in Manhattan and from my recent NYC cab experience, I realize that having a car in the city is a headache. As you can tell from all the work I've done to it, I planned on keeping this car for a long time. I'd like this car to go to a good home.
KBB is about $2600 in good condition, $2100 in fair condition for private party sale. My price is:
$1,250 FIRM for the car with factory front speakers, but no radio
$1,350 FIRM for the car with Polk db front speakers and Alpine CD/MP3 radio
Contact:
Send me a PM.
Pictures:
Specs:
- 2nd owner
Condition:
Maintenance:
Description:
Contact:
Send me a PM.
Pictures:
gargsta
Northwest (Sales)
Jul 5, 2012 07:09 AM
gargsta
Jul 4, 2012 11:46 PM
