Little DPFI Help guys??
Old May 18, 2011 | 02:01 PM
Jimmy's Avatar
Global Moderator
Default Little DPFI Help guys??
I'm searching and not finding a whole lot of information.
DPFI Civic, will not start by it's self.. Only way I can get it to start is a little shot of starting fluid in the TB, then it run's and idles fine..
Just cranks any other time.
Any help with someone who has experience with these is appreciated.. I do not
Old May 18, 2011 | 02:22 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Little DPFI Help guys??
Check your injectors.
There are only two.
The top one is your primary injector that should be running at idle and normal driving.
The secondary is the lower injector and should only come on under engine load conditions.
Sounds like maybe your primary isn't working and the secondary is taking over once you get it idling.
Old May 18, 2011 | 06:45 PM
Jimmy's Avatar
Global Moderator
There are only two.
I've got a spare intake manifold laying around, I'm gonna pull the primary injector and give it a try..
Any other ideas or anyone experienced this?
Old May 18, 2011 | 07:14 PM
pimpwagon's Avatar
take a test light and put it across the primary injector wires, to complete the circuit. crank the motor and see if it pulses while cranking. this will help narrow it down a bit.
Old May 19, 2011 | 07:42 AM
bodiez's Avatar
Hit the floor!
Have the same exact problem as you on my DPFI CRX. just sent out the injectors to get serviced. it was sitting a long time so one assumption is that they are clogged from a few years of buildup. I'll update if this solves anything.
This is a great idea. Would have never thought of this to test current pulsing. Will definitely try this.
Old May 19, 2011 | 12:59 PM
pimpwagon's Avatar
They are the only kind of Ideas i have...HAHAHAHA
Old May 19, 2011 | 01:04 PM
ThatRicerDaniel's Avatar
Really difficult to see on multi meter and even test light can be difficult. you can get a NOID light at autozone for a few bucks to test if they injectors are firing on time. That still doesnt tell you if the injector is working though. Remove the injector while the car is running and see if its actually firing fuel.
Old May 22, 2011 | 11:42 AM
bodiez's Avatar
Hit the floor!
DPFI has side feed injectors from the IM itself so sadly, you can not do this.
NewEvolutionIX
Aug 28, 2012 05:39 AM
Infamous war
Engine Management and Tuning
Aug 8, 2012 10:03 AM
Infamous war
Aug 8, 2012 07:15 AM
B18C5civic
Mar 27, 2006 12:10 PM
ImportPower13
Aug 17, 2005 11:50 AM
