rods
Old Sep 30, 2002 | 09:40 AM
Phoenix GSR's Avatar
Default rods
do any of you guys run higher than stock rpm on stock rods?
what rpm are stock rods good to?
is there any dif. between gsr/r rods and ls rods as far as strength/rpm limit?
TIA - I am thinking about B20 /w R head, but I am trying to limit my costs!
Old Sep 30, 2002 | 09:42 AM
Reid's Avatar
Global Moderator
Default Re: rods (Phoenix GSR)
ITR rods are different from GSR rods.
I'd have no qualms about taking ITR rods up to 9000+ rpm.
What crank are you planning to use in a B20 block that would allow you to use ITR rods?
Old Sep 30, 2002 | 09:50 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: rods (Reid)
I`d go aftermarket rods while it`s in pieces. Might save you some time/labor down the road.
Ryan
Old Sep 30, 2002 | 10:08 AM
Reid - I was actually going to be using the b20 crank (and most likely the rods), I was just curious as to the strength diferance in the differant rods... I dont have R rods (I thought they were the same as gsr which I do have a spare set of from my last motor) but I didnt know they were not interchangeable...
the common consesnsus seems to be dont rev to 8400 with the b20 rods..
what if I get them shot peened and use arp bolts in them?
[Modified by Phoenix GSR, 2:04 PM 9/30/2002]
Old Sep 30, 2002 | 11:53 AM
sgT's Avatar
sgT
with arp bolts and balancing the b20/b18 rods are just as good as gsr/itr rods.
Matt8314
Apr 24, 2017 07:36 AM
Shartek
Feb 16, 2008 01:49 PM
vtecdamian
Sep 22, 2004 11:40 AM
blackcruzan
10
Dec 25, 2003 01:42 PM
9KRacer
Apr 3, 2002 12:00 PM
