factory alarm going off all the time
I can turn the car off get out if i open the passenger side door the horn blowes off and on repedly until i switch the car to on position or crank up the engine
You said when you open passenger side door, then horn(alarm) blows off.
1st, call dealer and ask if this vehicle come with factory security system(call parts dept.)
I think it is.. If so, you need to suspect a switch at passenger side key tumbler.
It is located inside of door panel and attached back side of key cylinder.
3 wire connector and a pink wire confirms door unlock with key.
If this switch is faulty, it can send wrong signal to MICU(multi integrated control unit) and security system to alarm blow off.
good luck.
good luck.
Matt93eg
Audio / Security / Video
19
Feb 26, 2010 06:43 PM
