running poorly after mpfi swap, help please
i just did my mpfi swap on my 89 dx
matched up the colors at the dizzy, blue green to C1 and blue yellow to C2, original pin from C1 moved to B10, original pin from C2 moved to B12.
injectors are from d16y8
injector 3 to a5, injector 4 to a6. blk/yel wires soldered together, and to one of the blk/yel from old dpfi injector
injector 1 is dpfi yellow wire. injector 2 is dpfi red wire. blk/yel from inj 1 and 2 soldered together with other wire from dpfi injectors.
removed original wire from a3 and capped. removed original wires from a5 and a6, put a5 into a3, capped a6.
should i have soldered ALL the blk/yel wires together?
using d16y8 intake manifold, b18b tb
while running, it bogs out a bit.
sorta like rrrRRR rrrRRR rrrRRR __ rrrRRR rrrRRR rrrRRR __ ... etc
i hear a dripping after i shut off the car, from the back of the block, a pinging drip noise
profuse smoking, car didn't do that before
and a really scary clunking noise when i shut it off, from the drivers side
seems like the motor wants to spin for a few more revolutions than it should when the ignition is turned off
don't have throttle cable hooked up yet, but that shouldn't cause this issue should it?
i haven't moved the car since starting this swap, and have decided not to drive it till i figure this out
any help is appreciated
i checked the spark plugs. they are pretty black. cyl 4 plug had some oil deposits on it, plug was pretty loose. if i pull the spark plug wire off cyl 3 while it is running, it doesn't surge. sounds like misfiring, what might cause this?
well if it was loose I would check that to make sure they are all tight. Do that first. By the sound of it I would also change the plugs but lets tighten them down first.
My Bro did an MPFI swap in his 91 EF hatch. He swapped out his main relay. Come to find out the one he put in there was garbage. We switched the main relay back, and it reved out nicely, and ran like a raped ape.
I would also double check all wiring and connections to make sure everything is hooked up right, you would be surprised what you miss when you are tired, and or frustrated after working at something all day long.....lol believe me I know!
Oh yeah, I'm dropping a Y8 in my 93 EG as we speak. I will probably have it finished up tomorrow
the d15b2 is old, stuff is probably worn out. going to drop in the y8 today.
Dripping? Smoking? RRrrrr?
You did something wrong. Check every single thing that you did and make sure it is correct. Solder and heat shrink your wires. Do you have any CELs? What ECU are you using?
in the instructions here> http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
DPFI 1 is yellow and DPFI 2 is red. DPFI 1 goes to injector #1 (brown) on the mpfi manifold. (counting from dizzy) and DPFI 2 goes to injector #3 (blue). injector #2 goes to A3 and injector #4 goes to A7.
the 2 black/yellow wires from the DPFI injectors goes together and solder them both to all 4 red/black resister wires from the injectors. (doesnt need resister box)
thats your injector wiring.
Cut c1 and c2. from the ecu plugs, run them into the bay. from the cabin harness, run c1 to b10 and run c2 to b12.
in the bay, run c1 to dizzy blue/green. c2 to blue/yellow.
i didnt see you mentioned about TPS, switch both yellow and green wires around.
i followed that posted site for my recent dpfi to mpfi swap and it fired up the 1st try with no codes. remember dont loom the harness until you are satisfied with the outcome. once everything is said and done, then loom the harness.
there are 3 plugs left over.
well mines done correctly it was easy i built the harness in 2 days in my living room...used my std harness (dx i guess), not to hard at all just remeber that 2 injector grounds are existing the only 2 you need run to pins A3 and 7 i believe id have to go check, im curious though will my obd I plugs work or do i need to match the injector plugs they appear different
i got lost reading after injectors are from d16y8. i dont know where you got A5 and A6 from
DPFI 1 is yellow and DPFI 2 is red. Yep, just like mine
DPFI 1 goes to injector #1 (brown) on the mpfi manifold. Closest to timing belt, ok
(counting from dizzy) and DPFI 2 goes to injector #3 (blue). injector #2 goes to A3 and injector #4 goes to A7. I put DPFI 2 on injector 2, switched it around at the ECU as well. Injector 3 to A5, injector 4 to A7. I moved the red wire that was originally in A5, to A3. I'll move them around today to see if that makes a difference.
the 2 black/yellow wires from the DPFI injectors goes together and solder them both to all 4 red/black resister wires from the injectors. (doesnt need resister box) I didn't put the yel/blk together before soldering on the other 4 resistor wires, that's probably it too.
I did this different. C1 and C2 moved to B10 and B12 respectively.
ECU pins put in C1 and C2, ran to the blue green, blue yellow.
i didnt see you mentioned about TPS, switch both yellow and green wires around. I remembered to, don't worry =P
i followed that posted site for my recent dpfi to mpfi swap and it fired up the 1st try with no codes. remember dont loom the harness until you are satisfied with the outcome. once everything is said and done, then loom the harness. Wires are just chilling in the engine bay, soldered and heatshrinked.
there are 3 plugs left over. the old green dpfi, old brown dpfi, and the white IAT plug???
The thing that scares me the most is the horrid clunk from (I think) cyl 1 or 2. Crank keeps trying to rotate when I turn the car off. Could be my injector wiring? Gonna have fun troubleshooting today... ha ha...
Thanks for the help guys. I'll be back!
no no, you fool lol, i get what your trying to tell me, im not the noob here i just didnt know what the resistance was across those particular injectors, since there y8 injectors ill need obd II plugs, not a problem, and difference in flow over the obd I z6?
and the harness took me a little longer because i wanted to make sure it was all right, plus i soldered and heat shrinked tubed everything before it went back into the car, OP make sure you do this wire splices and black tape arent gonna cut it here
canadian ef: i think you are adding too much work switching a lot of wires around. i think you should put all the wires back in their original spot and redo this madness. the site i provided is very straight forward.
singlecam: im not calling anyone a noob. im trying to help from the best of my knowledge. obd2 clips/obd2 injectors
i do not know the flow difference from obd2 from obd1 injectors..i would think they are better than the old obd0 right? haha.
i do not know the flow difference from obd2 from obd1 injectors..i would think they are better than the old obd0 right? haha.All I did was match up the colors since they had the same scheme anyways...
If my dizzy is bad (which is possible), can I use an OBD1 dizzy in its place, with an OBD0 ecu if I re-pin it to accept the plug? just trying to rule things out here.
I have a CEL, but the LED on the ECU isn't lighting up at all, no flicker, nothing. Not with the car on, not with it off. =(
It ran for a little bit, CEL came up, turned her off. Saw the smoke slowly wafting out of the exhaust...
Tippyman
14
Mar 27, 2006 08:55 PM
ham
Jun 15, 2004 11:55 AM
