building lsv have some questions
Old May 17, 2011 | 10:19 AM
speedciv's Avatar
Default building lsv have some questions
i been reading on what to put in my lsv to make it reliabe and i see using gsr water pump and oil pump and i was just wondering why what makes them better then the stock ls water pump and oil pump?
Old May 17, 2011 | 10:28 AM
thirsk66's Avatar
Icon3 Re: building lsv have some questions
yeah go for it man build the lsvtec....and the ls water pump and oil pump are smaller than the gsr's propellers. you want your ls block to be running cooler and pumping a higher rate of oil pressure to your head since you would be using an oil line to be feeding the beast for vtec. all i can say is make sure you have your head b16 or gsr head whatever you go for to have the oil port/hole on the bottom of the head to be plugged up, take it to a shop and have them do so. i just got my b20v all put back together only to find out that my oil port wasnt plugged with a pin/metal circle. to explain it more in depth its the port hole that the oil goes through from a vtec block to vtec head, but since your using a non vtec block you would need to plug that port hole so oil doesnt pass through it anymore, hence thats what the oil line kit is for your oil source! do it right the first time no half assing it man
Old May 17, 2011 | 11:21 AM
ef1.8's Avatar
Default Re: building lsv have some questions
metal circle!!!!
Old May 17, 2011 | 11:56 AM
speedciv's Avatar
alright thanks that makes sense and im doin it in a 93 integra what ecu should i use? i been seein p28 or p72 but not sure which is better?
Old May 17, 2011 | 12:53 PM
speedciv's Avatar
and also what yr gsr should i get the pumps from just so i know before i order them and anyone know were i can get a lsv conversion kit for a good price?
Old May 17, 2011 | 10:30 PM
thirsk66's Avatar
go with a p28 ecu...alotta peeps out there running them, and as far as the gsr pumps go get them the same year as your bottom end (b18a or b18b) which ever you have
Old May 18, 2011 | 08:07 AM
m_shake's Avatar
All OBD2 b-series use the same oil pump(b18b, b18c1/5, b20, b16a)
15100-P72-A01
Doesn't matter what ecu you run because it'll need to be chipped and tuned regardless.
Might aswell get a cheap non vtec P06 and get a vtec conversion kit from xenocron
Old May 18, 2011 | 09:25 AM
speedciv's Avatar
i got a 93 integra did they make a gsr that year?
Old May 18, 2011 | 09:26 AM
DDTECH's Avatar
B series parts are interchangable. Doesn't matter what year.. get a 97+ oil pump and water pump.
Old May 18, 2011 | 09:38 AM
speedciv's Avatar
nice thank you
Old May 20, 2011 | 10:33 PM
thirsk66's Avatar
nice thank you
yoo bro last thing just gotta say if you do get a b16 head or gsr head whatever it may be...you should think bout fly cutting your pistons so you wont be slapping the valves with your pistons. its a fact man i recently just found out that you have to get this done in order to make your engine last awhile. and its a damn good idea to get the ARP main stud kit for your bottom end, on your ls engine. since the bolts that hold your crank on are equivalant or the same ones used on single cam engines, have the same tensile strength.
6speedEKhatch
Oct 28, 2009 12:50 PM
Dkahn18
Mar 17, 2009 05:47 PM
airmaxbri
Jun 3, 2008 11:49 AM
Gonzo
Feb 14, 2002 03:37 PM
