1997 EK Hatch dr door doesn't unlock/open with key
Old May 17, 2011 | 09:41 AM
maxmk8's Avatar
Default 1997 EK Hatch dr door doesn't unlock/open with key
The drivers side door won't open/unlock with the key, the door handle works and the inside mechanism works also.
But when the car is locked from the inside, its impossible to open it from the outside.
What should I look into replacing?
Old May 17, 2011 | 10:20 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 1997 EK Hatch dr door doesn't unlock/open with key
This isn't trick question is it? Does the lock cylinder turn back and forth? Did you go into the door to make sure nothing came loose?
Old May 17, 2011 | 11:10 AM
maxmk8's Avatar
Yes the cylinder goes back and forth. I didn't want to take the door panel off before I had the parts that I needed. So I wanted to get a sense for what it could be.
Old May 17, 2011 | 11:12 AM
The Grumpiest
If you don't take the door panel off to find out what is the problem then how do you plan on ordering parts to fix it? What if you don't need parts and it's an easy fix?
You can take the door panel off in less than 5 minutes.
Old May 17, 2011 | 11:23 AM
maxmk8's Avatar
Well if it's a common issue then I'd like to know what to look for...
square_1
13
Oct 13, 2010 07:11 AM
eG6haTchY
May 15, 2009 10:08 PM
SOKDO
Jan 30, 2009 05:18 PM
lilryan
Apr 11, 2008 06:08 PM
Import_Fan
Feb 15, 2007 04:19 AM
