Suspension & Brakes Theory, alignment, spring rates....
HELP!! Clunking with TEIN S & stock shocks on 06 S
Old May 17, 2011 | 02:07 AM
va20100's Avatar
Default HELP!! Clunking with TEIN S & stock shocks on 06 S
I got an 06 Type S with TEIN S TECH springs and stock shocks. From the first day I lowered the car, I started hearing a clunking sound / noise in the front passenger side (right side) when I drive over a sewer, a hole, a crack or a bump CLUK CLUK !! 2 days after it started on the left side also but not as often. I changed my stab links but that was not it. This is enough to drive me crazy!!!!
Old May 22, 2011 | 06:23 PM
DA garbage's Avatar
Default Re: HELP!! Clunking with TEIN S & stock shocks on 06 S
you need to tourq the top bolts. and If you took the axle out to instale tourq that too... Do this then post what happens. this is just the first thing you should do cause its the easiest.
Old May 25, 2011 | 12:52 PM
tariqjamil10's Avatar
Hi VA20100,
I have same issue with my 2002 Accord EX passanger side wheel is cluking, its doing that for quit some time now. Did not bother me but my wife is nosy about it. If you find any solution please let me know. It will help others aswell. Many thanks in advance. Also I will try DA garbage advise above on my next oil change.
Old May 26, 2011 | 06:42 AM
zerovandez's Avatar
What is a stab link? My brother has a 2004 Acura RSX and we installed H&R drop springs on it. After the install, his also made a clunking sound on the front end but I forget which side. We found that this was due to the sway bar links. So we disconnected them, drove the car around without any clunks, then reconnected at a settled ride height. The clunking came back. We then later found out that the sway bar bushings took shape to the stock ride height and created a bit of a "gap" which caused the clunking. We replaced them and no more sounds. So look into your sway bar links although I have a feeling that you meant sway bar link when you mentioned "stab link."
Old Jun 2, 2011 | 02:14 AM
va20100's Avatar
Found the problem, I have spring clatter!!!
Old Jun 2, 2011 | 03:16 AM
grumblemarc's Avatar
The Grumpiest
Why? You shouldn't if you installed them correctly.
HA0LEFIED
Honda Civic (2006 - 2015)
22
Jan 17, 2008 07:20 PM
neeks
Suspension & Brakes
Sep 3, 2006 07:02 PM
AllSpedup04
Oct 12, 2005 08:05 AM
GreyDc2
Jul 26, 2005 11:09 PM
japmarket1
Suspension & Brakes
Apr 24, 2005 08:06 PM
