anybody know the differences between steering knuckles on 88,89,90,91 models ??
Old May 17, 2011 | 01:12 AM
crxaddikt's Avatar
Default anybody know the differences between steering knuckles on 88,89,90,91 models ??
my car is a 1990 CRX SI,
my steering knuckle on my passenger side is bent from hitting a curb at a diagonal angle a couple years ago, and since then alignment shops say that they arent able to do an alignment properly until i get a new steering knuckle.
plus it wears through tires pretty fast too, i've just been buying used tires for $25 each.
so i was going to be looking & around for a used knuckle/hub assebly (with wheel bearing still in it), i wanted to know the differences between the knuckle/hubs between all the different CRX models from 1988 through 1991
i wanted to know s if a knuckle/hub from any different CRX models, (like: 88,89,90,91,..DX, HF, SI, would fit the 1990 CRX SI ??
ool
Old May 17, 2011 | 04:08 AM
dc5itracer's Avatar
Default Re: anybody know the differences between steering knuckles on 88,89,90,91 models ??
The olny diffrence is the hf hub but all dx/si are the same hub,bearing,and brakes no matter the year
Old May 25, 2011 | 06:20 AM
crxaddikt's Avatar
alright, thanks for the reply and info
knowing that its the same on the DX/Si for all years will make it a lot easier for me to find a used pass. side Knuckle/Hub assembly.
i need one cause my steering knuckle is bent from hitting a curb a while back,
all the parts that were damaged were replaced except the steering knuckle, and that is why the car cannot get alignment properly, but it will once i get the knuckle.
inegma29
Feb 7, 2008 12:15 PM
alscrx
Jan 25, 2008 06:51 PM
casca
Jan 26, 2007 06:26 AM
jaydm98
Sep 9, 2003 03:33 PM
