Honda CR-V & Element 2WD & 4WD Element & CR-V
Which is a better deal: Compare 1 used vs 1 Certified Pre-Owned
Old May 16, 2011 | 09:12 PM
crvnoob's Avatar
Default Which is a better deal: Compare 1 used vs 1 Certified Pre-Owned
Both cars are 2009 EXLs, pretty much identical in terms of mileage and appearance. All-in prices are $22,000 and $24,000
The Certified Pre-owned has the following advantage:
-1 extra year/12,000 miles of bumper to bumper.
-2 extra year/40,000 miles power train warranty
-It has gone through the 150 point inspection
1. Do you think that these 3 things are worth an extra $2,000?
2. I assume the dealer will show you the Certification report and what they fixed?
Old May 18, 2011 | 12:27 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Which is a better deal: Compare 1 used vs 1 Certified Pre-Owned
I'm going to say "no." But it also depends on where this used CRV came from. Private owner? Or Some used car lot.
You can tell some history by doing the basics. But the bottom line if it's still covered under the 3/36 warranty, I would not worry about it to save $2,000.
There are independent Honda shops that will do an inspection for about $100.
Mark Hurd
Apr 26, 2015 06:54 AM
octavio714
Honda Civic (2006 - 2015)
Jan 6, 2011 08:36 PM
Jap_Spec_Imports
Aug 31, 2009 11:59 AM
B18CR-X
Nov 11, 2003 12:37 PM
onyx00
Jul 11, 2002 12:05 PM
