FS/FT: LS 'teggy Turbo Setup for JDM Front Parts
$550 THIS WEEKEND!
I have an essentially complete turbo setup for an LS 94-01 Integra (B18B1) that I'd be looking to trade for some JDM front end parts, or sell. Everything fits fine (intercooler piping, etc) and should need no modification. I got it off a friends Integra and with the current mani you may be able to keep A/C, I'm not positive.
Kit includes:
-XSPower (Ebay) 57 Trim turbo
-XSPower Intercooler (fits nicely in the mouth of a 98-01)
-Blitz 38mm BOV
-Drag Manifold (Not sure on model, I'll have a pic)
-Oil feed/drain
-Tapped LS oil pan
-Aluminum piping w/ all couplers
-Downpipe that mates right up to a testpipe/cat on an LS. (slightly messy)
-Wastegate dump tube
-OBD1 440cc Injectors
-Chipped/Socketed OBD1 P75 ecu basemap'd to run 8psi.
This kit is pretty much bolt on and go. I got it from a friend that was running it in his LS last week. You'll need a few things, mainly a 38mm wastegate, jumper harness to run ecu, and OBD1 injector clips. Thats it, then your ready. Its not the prettiest, but it gets the job done. He pulled on subies and s2k's all day, LS was bone stock.
I was planning to install it but I'll need a new clutch because mine is going out, and I'm not sure this is the right route for me anymore. I'd much rather see if I can score a JDM front in a trade. I can add a little cash if necessary.
PM me if your interested/have questions. You can also text me at 443-616-7705.
I'd sell outright for $750 OBO.
Kit includes:
-Blitz 38mm BOV
-Oil feed/drain
-Tapped LS oil pan
i have a gsr longblock with skunk 2 manifold if your interested in trading and im also running a abp db7 so bump for you.
Acura_I-RS
Mar 12, 2005 04:34 AM
dump, front, fsft, honda, hondamarketplace, integra, intercooler, jdm, ls, lsintegradb7, marketplace, parts, setup, teggy, turbo, wastegate
