Classic Hondas All Pre-1988 Hondas.
How do you change front marker bulb in 86 accord?
Old May 16, 2011 | 09:28 AM
manntis's Avatar
Default How do you change front marker bulb in 86 accord?
as the title says I'm trying to change the bulb in the right front marker light on a 1986 Honda Accord. When the headlights are in the up position I can see the bulb mounting assembly, but there's no room to get in there to change it.
What's the trick? The lenses are mounted in such a way that I can't see any external screws and the Haynes manual is useless.
Old May 16, 2011 | 02:51 PM
poorman212's Avatar
Default Re: How do you change front marker bulb in 86 accord?
In the bumper below the light there is a "plastic" piece/window/insert.....pull it out...can't remember if it is top first or bottom first......once out you'll see the screw that needs to be removed, then the lens will slide out.
jneusch
Jan 30, 2008 06:22 AM
philosofy1
Aug 23, 2007 08:45 AM
ddg2sailor
Aug 9, 2007 11:15 AM
sshan25
Mar 16, 2006 11:29 PM
ekcivic9
Jul 2, 2005 04:25 PM
