how to tell if you are low on tranny fluid?
Old Sep 30, 2002 | 07:18 AM
magic hat #9's Avatar
Default how to tell if you are low on tranny fluid?
are there symptoms of being low on tranny fluid? last night i drained the fluid and put 2.75qt back in, but i spilled at least .25qt. will the tranny make a sound or feel off when low on fluid?
Old Sep 30, 2002 | 07:23 AM
uNF$@#!'s Avatar
Default Re: how to tell if you are low on tranny fluid? (monkey_truckR)
if you think your low,
refill.
having difficulty getting it into gear is an obvious sign.
Old Sep 30, 2002 | 07:24 AM
JPP's Avatar
JPP
You should not take any chances and check the proper way.
With the car on leveled ground, remove the refill bolt and check with your finger if the oil goes right up flush with the edge of the hole.
Old Sep 30, 2002 | 08:59 AM
uNF$@#!'s Avatar
Default Re: how to tell if you are low on tranny fluid? (JPP)
thats the proper way?
i cant fit my finger in there
Old Sep 30, 2002 | 09:10 AM
JPP's Avatar
JPP
Default Re: how to tell if you are low on tranny fluid? (Soup ****)
Well that's how it's explain in the manual.
They don't however mention the size of finger needed to fit in the hole.
Old Sep 30, 2002 | 10:55 AM
Tommy_Gunns's Avatar
When changing your tranny fluid, just pour new fluid in until it starts coming out of the fill hole (that's the proper level), make sure your car is leveled.
You only need 2.2 litres (2.3 US qt) during a tranny oil change so I think you're fine.
Old Sep 30, 2002 | 11:07 AM
Black R's Avatar
25 Year Member
.....put your finger in the hole!
Old Sep 30, 2002 | 12:16 PM
Default Re: how to tell if you are low on tranny fluid? (Tommy_Gunns)
i'm in good shape, i might even have too much fluid.
if you look at the R the rear is slightly higher than the front, but on jack stands they'll be at the same level. this means you'll end up with a bit extra fluid. i'd rather have a little drag from extra fluid than be low and have an unprotected tranny.
Old Sep 30, 2002 | 12:36 PM
-Whitey-'s Avatar
ooops my car was jacked up fromthe front and took excatly 2 us quarts i think i might need to add more heh
Old Sep 30, 2002 | 12:43 PM
Dave-ROR's Avatar
Default Re: how to tell if you are low on tranny fluid? (one_honda)
I bet some of that fluid just sat in the housing during the draining process..
Old Sep 30, 2002 | 12:59 PM
4-1-1's Avatar
Default Re: how to tell if you are low on tranny fluid? (Dave-ROR)
Anyone know the estimated miles people go before changing it?
Old Sep 30, 2002 | 01:05 PM
-Whitey-'s Avatar
damn you i bet your right well time to do it all over againthe right way
let this be a lesson to all do it right the first time or do it twice
Old Sep 30, 2002 | 01:37 PM
Dave-ROR's Avatar
Default Re: how to tell if you are low on tranny fluid? (4-1-1)
It varies. 3000 miles for mike k, 30,000 for me
Old Sep 30, 2002 | 01:45 PM
AssPenny's Avatar
I do mine every other oil change
Old Sep 30, 2002 | 07:02 PM
Default Re: how to tell if you are low on tranny fluid? (AssPenny)
every 15k miles is plenty good; my tranny oil comes out just slightly dirty/brown.
Old Sep 30, 2002 | 07:15 PM
B2FiNiTY's Avatar
I do mine every 15k. It's still nice and clear.
Old Sep 30, 2002 | 07:25 PM
Eric R's Avatar
Overheating around the trans area but, that the extreme case. By then, you did some damage to it. (*grinding noise on the synchros accompaning it...*)
philkehn
Jan 21, 2007 05:03 AM
r0dxx
Jun 18, 2005 10:36 PM
01-1293
Jul 9, 2002 08:34 PM
Chip398193
Oct 23, 2001 01:47 PM
