Slide pin grease on disc brakes?
Old May 16, 2011 | 06:31 AM
CWBETB's Avatar
Default Slide pin grease on disc brakes?
I used some Valvoline Synthetic grease on my slide pins on my rear discs. The manual itself says "silicon grease". Is it safe/ok to run with the synthetic grease or shoud I remove and hunt down some slicon grease?
Provides excellent high- and low-temperature protection (-25°F to 400°F) over conventional greases
DuraBlend Grease is a synthetic blend extreme-pressure, heavy-duty automotive grease specially formulated to protect disc brake wheel bearings, suspensions, universal joints and constant velocity (CV) joints.
Old May 16, 2011 | 09:42 AM
slowcivic2k's Avatar
Default Re: Slide pin grease on disc brakes?
Do not use petroleum lubricants on any brake parts, when your rubber ended caliper pins seize up you will regret ever doing that. Silicone grease does not swell rubber very much (if at all) allowing the parts to move freely. Find a commercially available brake lubricant.
Old May 16, 2011 | 12:05 PM
greenchad's Avatar
I use this
http://www.permatex.com/products/Aut..._Lubricant.htm
Old May 16, 2011 | 07:30 PM
raffaelli's Avatar
Originally Posted by greenchad
+1
hmoobvwj
15
Aug 10, 2013 03:50 PM
Mr.Speed
Jun 15, 2010 03:37 PM
jason_alt
Nov 21, 2004 10:14 AM
typeeg
Jul 23, 2004 06:43 PM
mr_mbuna
Jan 20, 2003 09:13 PM
