d17a2 gx piston
would 01-03 gx pistons drop in d17a2 with good p2v clearance
zeal calculator is giving me a static comp of 11.87.1 and a effective comp of 11.71.1 , and a piston to deck height of , 0.031 but not sure if this is below or above cylinder i think below not sure please help
Stock cam it shouldn't be a issue... google "pms pistons" little to no valve reliefs.
These pistons are also kinda hard to get
13010-PMS-A00 std size 6 available
13020-PMS-A00 .25 os 5 available
13030-PMS-A00 .50 os none available
Take this with a grain of salt: I also remember a N/A build being done with the gx pistons that resulted in higher compression. I would imagine it is totally possible with no modification.
I don't believe anyone has actually used gx pistons in a NA build yet. Jonathan2006 and Bomerman both talked about using the pistons but Bomerman backed out and Jonathan2006 hasn't sourced them yet for his build.
PrecisionH23a
Mar 17, 2005 06:12 PM
95c1v1cs1
Jul 28, 2004 09:44 AM
Vracer111
May 17, 2002 08:40 AM
