pulley's on a zc...
Old Sep 30, 2002 | 06:56 AM
tunedcivic's Avatar
Default pulley's on a zc...
my buddy wants to put power pulleys for hsi crank and alternator on his zc. he doesnt have the internet so he asked me to post this. what pulleys do i need to tell him to get? the 89 integra or the 88 crx like he has?
Old Sep 30, 2002 | 07:24 AM
Magick211's Avatar
Default Re: pulley's on a zc... (tunedcivic)
Pulleys for the 88-91 Crx si will work, But i would stay away from lightend crank pulleys if i were him
Old Sep 30, 2002 | 10:31 AM
ScottEK's Avatar
Default Re: pulley's on a zc... (CivicBoyZC)
I don't know if this matters but if you check Dmoore's site I believe it says not to use them because they are different diameters.
Old Sep 30, 2002 | 11:20 AM
spettinger's Avatar
Default Re: pulley's on a zc... (beta13)
i wouldn't do it, unless the bottom end is completely balanced, it will throw the crank off and possibly spin a rod bearing or damage a journal.
Old Sep 30, 2002 | 01:43 PM
Caleb V's Avatar
Default I would go the other way and add an A6 pulley.
The longevity of the motor will be highly beneficial in the long run with a harmonic balancer. It is a bit heavier but so what get a lightened/chromoly/aluminum flywheel where the weight removed will be swinging in a larger arc and help you out alot better.
Caleb
7 Hondas and still counting. Oh yeah and 2 Honda bikes too.
drjondurst
Oct 4, 2006 03:04 PM
K-Drum
Jul 19, 2004 08:09 AM
gregv
Feb 16, 2004 08:03 PM
VTgringo
11
Aug 2, 2003 09:07 AM
quis23
Jul 14, 2003 10:40 AM
