hondata and liberty tranny
Old May 15, 2011 | 07:59 PM
SPOOLINmatt's Avatar
Default hondata and liberty tranny
I never had this issue until i got my liberty trany last year. Hondata recognizes each gear in the log until i get to 4th and then it flips between 4 and 5 in the log...which means my boost tables flip between tables(I have to set 4 and 5 the same)
I dont have a 5th gear...its not a huge issue...just a little annoying.
Old May 16, 2011 | 05:24 AM
mtber's Avatar
Default Re: hondata and liberty tranny
Simply change the gear ratio under parameters....
Old May 16, 2011 | 05:25 AM
ive done all that
it will read 4th, then flip to 5th, and sometimes flip back to 4th on the log.
Old May 16, 2011 | 05:26 AM
mtber's Avatar
Originally Posted by SPOOLINmatt
ive done all that
My guess is your ratio settings are wrong for your tranny...
That is the only reason you should be seeing the issue you are experiencing.
Old May 16, 2011 | 05:52 AM
ive tried every stock fd ratio liberty has and every 4th gear ratio liberty has.
Old May 16, 2011 | 06:21 AM
mtber's Avatar
Post a datalog..
Also post what gear ratio settings you are using.
Old May 18, 2011 | 06:35 AM
josephcmiller2's Avatar
Just guessing because I don't use HONDATA, but maybe enter a completely ridiculous value for 5th gear so it will never cross the threshold.
homey dont play dat
Jul 20, 2016 06:27 AM
whp
Nov 16, 2004 05:16 PM
turtle-eg
Dec 2, 2003 04:57 AM
Aeka GSR
Sep 30, 2003 03:39 AM
