FS: ITR 5 lug, OBD-0 PR3, 1990 Integra
Trying to clean up and get some of this stuff out of my garage..
ITR 5 Lug Setup - $950 - Brembo crossed drilled rotors on the front with HAWK pads, these are 32MM and will work with USDM axles.
OBD-0 PR3 Ecu - $125 - Works perfect, led light still functions, does not throw code 13 for BARO/Atmospheric pressure like I have seen some do in the past.
1990 Acura Integra GS - $1700
Car has a B18B1 motor in it, I believe it skipped time this past friday, there is some ticking in the head, and the ecu is throwing, codes 9, and 4. Cylinder Sensor and Crank Position Sensor.
JDM B16 transmission, Skunk2 Pro C coilovers, JDM 1 Piece Headlights, Skunk2 Dual Bend shifter with Skunk2 ****, Greddy 4-2-1 header, Tanabe exhaust, Exedy clutch and Clutchmaster's 9lb flywheel.
If you have any more questions you can PM me or text/call 214-250-8677. All prices are priced for lowballers, so make an offer. I wanna get rid of this stuff..
Haven't checked this in a minute.. 5 lug sold real quick.. BUMP. Will sell the DA for $1350 cash. Need this thing gone. Have blue texas title in hand.
