Champ White paint question...
PPG has NH-0 and its offered in a higher line called DBC and it covers very good for $376.00 for a gallon which reduced it gives you two gallons sprayable that's enough to do inside and out,they also have a lower line called OMNI that will run you $142.00 but I wouldn't reduce it 1-1 because it is a little thinner than DBC both good products take your pick but always use the good clear I've learned from experience
