1994 Honda Accord Ex Need Help Plz dropped valve
Old May 15, 2011 | 10:57 AM
eugenecrts's Avatar
Default 1994 Honda Accord Ex Need Help Plz dropped valve
I Have a 1994 Honda Accord Ex 2.2 Vtec I do not know for sure what all the damage is so far working on taking head off to see how bad damage is but i need help to see what makes and models of honda have and engine in it to fit my car so if the engine is no good i know which ones to look for thanks for the help
Old May 15, 2011 | 01:56 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1994 Honda Accord Ex Need Help Plz dropped valve
That engine is called F22B1. Look at the exhaust manifold, then to the left but before the transmission, there are a couple of machined pads with numbers cast/stamped into them. One IIRC is partial VIN in smaller letters, and in larger letters will be 'F22B1'. But be warned there are two different F22B1s, the 94/95 OBDI and the 96/97 OBDII.
If the head/cylinder/piston are damaged, before having extensive machine work done, get an imported F22B1 cylinder head or engine quote. It may be cheaper/ faster to remove/replace than to remove/rebuild/reinstall.
ls1formula98
Dec 22, 2014 03:02 PM
Scottelaxe
Jul 20, 2013 01:45 AM
Misstamika
Jan 22, 2006 05:59 PM
