D16z6 CRX Chokes at low rpms... Help!
Old May 14, 2011 | 08:04 PM
VtecCr8zy's Avatar
Default D16z6 CRX Chokes at low rpms... Help!
Im very new to any type of swapped honda. I have owned some before but not swapped. I just got this crx and it seems very good at anything higher than 3k RPMs it does well but on lower RPMs it kinda chokes a bit. Please if you got any info or links to a thread that I havent stumbled upon please share. anything would be helpful. 89 CRX SI full OBD1 Conversion, 95 D16Z6, Full exhaust from header back, new head gasket... Does well when warm but horrible when cold. Starts up everytime just fine then starts autoreving. If Theres any info you need from me please ask aswell. I'm not much of a tech but always looked at the hobby from the sidelines. First project here. Thanks guys. You guys rock!!! So much good knowledge on these forums. Keep up the good work.
Old Aug 30, 2013 | 08:39 PM
dcnatty1's Avatar
Default Re: D16z6 CRX Chokes at low rpms... Help!
did you ever find out the problem? I just bought a 89 with the same problem and was wondering what it may be.
Old Aug 31, 2013 | 01:33 AM
DCRB's Avatar
timing belt could be retarded a tooth, check that
Old Sep 2, 2013 | 09:15 PM
dcnatty1's Avatar
Its the TPS.
CRX Venezuela
Mar 18, 2009 10:55 AM
BoostingREX
Aug 19, 2005 03:31 PM
JDM RHD eg6
Dec 11, 2004 12:34 AM
