(((B18C))) ITR HIGH COMP. FRESH, sfwd shell..!!!!!
WHATS UP I GOT A B18C HICH COMPRESSION FULL SWAP FOR SALE ITS COMES WITHA A HACKE B SERIES HARNESS THAT MOTOR CAME WITH I HAVE A JDM P72 ECU WITH JUMPER HARNES TO PLUG IN TO OBD 2B ALL SENSORS ,AXELS , SHIFT LINKAGES , RADIATOR AND FAN, HYTECH REPLICA HEADER AND TEST PIPE , ETC MISSING MORE BUT MOTOR GOT TUNED ON S300 MADE 205/190 ON STOCK IGNITION I WILL PROVIDE MAP THROUGH EMAIL OR UPLOAD IF U BRING A HONDATA ECU, MOTOR IS STILL IN CAR BUT NOT FOR TO MUCH LONGER SO IF U WANT TO SEE IT RUN LMK...
.ASKING 5500.00
TEXT 732 966 5732 OR PM THANKS
ENGINE BLOCK- 270psi across board
B18C ITR BORED .20 OVER AND DECKED
WESICO 13.0-13.5 PISTONS
EAGLE H BEAM RODS
ACL RACE BEARINGS
NEW WATER PUMP -HONDA
NEW OIL PUMP - HONDA
ALL NEW ORINGS AND THERMOSTAT/SENSORS
GATE RACING TIMING BELT
HEAD
STOCK B18C ITR HEAD MILLED
PRESSURE TESTED
AND VALVE LASH
68 MM THROTTLE BODY
RC 440 INJECTORS
BLOX FPR
NEW COIL IN DIZZY
TRANS
J4D LSD
MINT NO GRINDS OR POP OUTS
ALWAYS GENUWINE HONDA FLUID
68,000 MILES APROXIMATLY
ALL WORK WAS DONE BY JOEL@ SPEED-THEORY RACING DEVELOPMENT IN FAIR FIELS NJ
AND RECIPTS FOR PARTS AND LABOR WILL BE PROVIDED
ALSO SELLING A sfwd shell 01 GSR CAGED , SUMPED TANK , LINE LOCK, INTERIOR FABBED FOR CAGE FITMENT ALREADY ,BRAND NEW EXO SPEED 3 PCS FRONT END , BODY HAS 60,000 MILES ON IT BLACK MINT CONDITON , NO SEATS OR CARPET BET HAVE EVERYTHING ELSE
PM FOR MORE DETAILS AND REST OF LIST OF STUFF and price
.ASKING 5500.00
EAGLE H BEAM RODS
ACL RACE BEARINGS
HEAD
PRESSURE TESTED
AND VALVE LASH
68 MM THROTTLE BODY
RC 440 INJECTORS
BLOX FPR
NEW COIL IN DIZZY
TRANS
J4D LSD
