TW 1991 civic wagon 4wd clean title
Moneys tight and i think i need to find a new hobby so im contemplating selling my baby.
1991 Honda Civic Realtime 4WD wagon, only about 5-6000 are left on the road in the 88-91 generation according to www.civicwagon.com so coming across one with a clean title and a book of reciepts since my ownership in august of 09 is even rarer.
It didnt come with A/c but i hooked a system up it just needs a recharge jiffy lube doesm for 140$ or so.
roof is white..**
The car also will come with a lifetime allignment at firestone a 160$ value.
jdm clear corners-100$
will come with a rare set of enkei (84's) auronautics 15x6 with falkens with ridebale tread.
also a set of even rarer eneki 81's i was planning on rebarreling to a 2.5 inch lip at memory fab but i just dont know if i want to pursue this type of hobby any more.
no center caps for either.
Heres the stats
Clean title
Limo tint all rear windows
267k miles
new replacement tranny yes still 4wd.. about 30k ago
timing belt done about 30 k ago along with waterpump at the same time
i have reciepts for every part replaced
outter tie rods, rta bushings rear diff bushings , front motor mount , rear motor mount all recently like within 5k
93 Vigor calipers (same as 96 spec type r )
DA ls rotors
ceramic pads.. could use a good overall brake service though. .
Suspension techniques 22mm rear sway
suspension techniques drop forks ( no longer available)
suspension techniques rear lca with camber adjustment ( no longer available )
2.25 " exhaust all the way back
Koni yellow with ground controls beefer rear spring i forgot what the wieght was but its just a lil stronger than OTS rates.
rear shocks have the extended top hats.
OEM roof rack
Nardi Gold polish woodgrain with nrg hub setup alone cost over 500$
89 honda prelude foglights
never had a serious accident , did have a minor fender bender ( hence the white hood ) and a small curb into small rivine , i replaced everything though the only thing still damaged is the headlight housing skeleton but if you look at it you couldnt tell it was in a accident. all the pictures are current
i have invested about 6.5k just keeping this thing on the road id be content to get about 3.6k or im not selling it
these cars will be a thing of the past soon and to me its a piece of honda history i planned on keeping this forever but i got debt and i gotta get my life on track
roof is white..**
Heres the stats
Clean title
267k miles
DA ls rotors
OEM roof rack
imzjustplayin
Oct 10, 2009 10:29 PM
1991, 4wd, 88, 91, ca, california, civic, classified, craigslist, honda, rt, rt4wd, sale, shuttle, wagon
