Help me with this Relay.. which is it?
Old May 14, 2011 | 01:37 PM
Jimmy's Avatar
Global Moderator
Default Help me with this Relay.. which is it?
I just recently purchased an 91 honda civic hatchback..
This relay is near the dash on the driver side, just dangling..
Could anyone verify which relay this is?
Main Relay? I know the 92-95 honda civic main relay is completely different..
12v 30amp
Old May 14, 2011 | 07:42 PM
zach53's Avatar
Default Re: Help me with this Relay.. which is it?
thats gunna be your main relay bro
zach53's Avatar
its goes under the dash to the left of the fuse box
Old May 14, 2011 | 08:01 PM
crx_si-r's Avatar
that is NOT the main realy. it appears to be an aftermarket relay. most honda relays are black and hard plastic casing.
the main relay has a rectangular plug with 8 slots but only 7 wires going to it. it will also say Mitsuba
Old May 14, 2011 | 08:20 PM
zach53's Avatar
hahaha now that i c the pic i feel dumb lmao.........it sounded like it was in tha same area tho lol.....
Old May 28, 2011 | 02:58 PM
Jimmy's Avatar
Global Moderator
Bumping this back up, i need a hand here fellas.. I just realized i never posted a picture of the wires or color of the wires going to this relay..
I need to know what relay this is and can't figure it out, whichever it is.. it's bad.. somebody has had the case off and it's causing issues..
seems like two black/white wires, blue wire, and red/black..
Old May 28, 2011 | 03:01 PM
Jimmy's Avatar
Global Moderator
I have this relay from Honda
http://www.hondaautomotiveparts.com/...VIN+Number+---
It looks identical to the ''made in china'' one that's in the car, but I just need to verify it's the right relay
Old May 28, 2011 | 03:05 PM
dacrxguy's Avatar
The blk/white wire looks like the starter signal what pin is it connected to on the relay.
Old May 28, 2011 | 03:09 PM
Jimmy's Avatar
Global Moderator
Makes sense.. cause when this relay acts up with the key all the way on and me trying to start it.. nothing happens then u wait a second or ''tap'' the relay and it will work.
The part # I listed and linked to, what is that for?
here is another pic of location of the relay.. I'm just kinda new to this year/made/model civics.
Old May 29, 2011 | 04:12 PM
dacrxguy's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/safe-jump-starter-relay-89-crx-2659536/
http://2.bp.blogspot.com/-SBDEzzL0dQ...ing-System.gif
It look like the starter relay
deadhead23
Jan 15, 2021 10:43 AM
broken crx
Aug 1, 2006 03:02 AM
navin
15
Aug 1, 2004 09:14 AM
el_Presidente
May 11, 2003 01:36 PM
