Stock Integra Parts
98-01 ABS Modulator-$50
98-01 ABS Modulator Bracket-$10
ABS ECU-$20
Center Console Bracket-$5
Center Console Plugs-$5
Brake Booster Vacuum Line Bracket-$5
Radiator Bottom Rubber Bushing (I can only find one)-$2
Relays-$10/each
Turn Signal Socket-$5
Hood Prop-$10
Under Steering Column Plastic (missing coin holder)-$10
Maintenance Required Reset Switch-$10
Negative Battery Cable-$10
Dash Vents-$5 (a little dusty)
Quarter Panel Window Plastics (includes clothes hook on driver side)-$20
Power Steering Rack and Pinion(has torn boot on driver side and one tie rod boots is torn from sitting around for 4 years)-$40
Gas Door-$10
Hood Release Lever-$5
Evaporator Core-$25
Front Wiper Motor-$25
Rear Wiper Motor-$10
Auto Cruise Unit P72 MT-$20
Hose (I'm not sure what this is called but I think it connects to the heater hoses)-$10
Random Brackets (message me about these)
Arm Rest Hinge-SOLD
Coolant Overflow Bottle Bracket-SOLD
Door Dome Light Switch/Pin-SOLD
B-Series Automatic Transmission Flexplate w/ Bolts-SOLD
Parking Brake-SOLD
spare tire hold down-SOLD
AC heater blower motor-SOLD
front bumper bolts-SOLD
front lower control arms-SOLD
bare subframe-SOLD
license plate lights-SOLD
hood hinges-SOLD
horn-SOLD
fender brackets-SOLD
clutch fluid reservoir-SOLD
d-series fuel pressure regulator-SOLD
power steering reservoir bracket-SOLD
seatbelt grey bolt covers-SOLD
under hood fuse box with fuses and relays-SOLD
USDM ITR/GSR 24mm front sway bar-SOLD
gas tank/fuel gauge float-SOLD
front bumper reinforcement bar w/styrofoam-SOLD
dome light-SOLD
gas cap-SOLD
rear seat strikers-SOLD
under dash fuse box with fuses-SOLD
gas door release lever-SOLD
a-pillar plastics-SOLD
map light-SOLD
passenger side power window motor and regulator-SOLD
cup holder-SOLD
window fluid reservoir with harness-SOLD
trunk lock-SOLD
door panel lock driver and passenger side black bezels-SOLD
shiftboot cover-SOLD
coolant reservoir-SOLD
cigarette lighter with ashtray-SOLD
hatch plastic (black)-SOLD
dash cluster harness-SOLD
main relay-SOLD
trunk actuator-SOLD
rear bumper reinforcement bar w/styrofoam-SOLD
cluster bezel plastic-SOLD
kick panel plastics-SOLD
driver side dash bolt cover-SOLD
trunk light-SOLD
trunk key cylinder-SOLD
coin holder-SOLD
power door lock control-SOLD
black quarter panel & rear trunk plastics -SOLD
fuel pump assembly-SOLD
passenger airbag-SOLD
LS door panels-SOLD
rearview mirror-SOLD
under radio tray-SOLD
driver side power window motor and regulator-SOLD
power steering high pressure hose-SOLD
bare steering column-SOLD
srs clock spring reel-SOLD
abs relay-SOLD
pedal set-SOLD
gsr spoiler w/ brake light-SOLD
quarter panel moldings-SOLD
stock shifter and **** (**** is a little scuffed up)-SOLD
hood latch w/cable-SOLD
vapor canister/charcoal canister-SOLD
oem 98-01 amber turn signals-SOLD
2000 GSR gauge cluster-SOLD
rear filler panel-SOLD
complete moonroof assembly-SOLD
steering wheel w/airbag-SOLD
ABS ECU-$20
Relays-$10/each
Hood Prop-$10
Gas Door-$10
Evaporator Core-$25
Arm Rest Hinge-SOLD
Parking Brake-SOLD
bare subframe-SOLD
hood hinges-SOLD
horn-SOLD
dome light-SOLD
gas cap-SOLD
map light-SOLD
cup holder-SOLD
trunk lock-SOLD
main relay-SOLD
trunk actuator-SOLD
trunk light-SOLD
coin holder-SOLD
LS door panels-SOLD
abs relay-SOLD
pedal set-SOLD
