99 civic ls swap?
Old May 13, 2011 | 01:52 PM
nicolas1320's Avatar
Default 99 civic ls swap?
ok guys have a question about this swap,i know there is like 20 forums with this info but just want any body that has done it to please help me out. i got a 99 civic ex and im going to put a 95 integra ls on it, ofcourse its obd1 and mine is obd2b so im using the d16 injectors sence they are the same cc's and changing the ignition to a 2000 integra.but the question is can i run the engine with my stock ecu and if i do will it pass inspection? thanks.
Old May 13, 2011 | 02:35 PM
98civdx's Avatar
Master Detailer
Default Re: 99 civic ls swap?
Depending on your state you can fail simply becuase the engine is older then the car. It must be the same year or newer.
You can run the integra ecu, but you need a 0bd2b to obd1 jumper harness.
Old May 14, 2011 | 01:28 PM
yo sorry i took to long,well the engine is not going to be a problem with the year,and i do have a stepdown harness and a p28 to tune it, so u think the integra ecu is better
Old May 14, 2011 | 02:26 PM
also wondering if the tork mount brakets fit, i know the ac braket has to be changed to fit the singlecam ac compressor on
Stanced_b20
Nov 29, 2018 05:03 PM
Robert Vasquez
May 7, 2017 02:39 PM
titan2hell
May 17, 2011 08:08 PM
bimmeracer
12
Sep 23, 2007 04:16 PM
hondacivicvtec99
Mar 16, 2003 05:11 PM
