poor mans type R wont rev past vtec
Old May 12, 2011 | 08:11 PM
hyracer's Avatar
Default poor mans type R wont rev past vtec
I have a poor mans type r motor. Jdm gsr block and b16 head. When I floor it the rpms go up but it won't rev past the point vtec engages. vtec hits then its like theres a rev Limiter. Any ideas what it could be? IT only does it in gear when I floor it. Fluid levels are.good and the motor is warmed up. Any ideas will help. Thanks. The car runs fine besides this problem
Old May 13, 2011 | 08:56 AM
calcal's Avatar
Default Re: poor mans type R wont rev past vtec
does check light goes up when the limiter hits?
Old May 13, 2011 | 12:34 PM
hyracer's Avatar
It doesn't t have a limiter. and no check engine lights when this happens.
Old May 13, 2011 | 12:37 PM
hyracer's Avatar
Oh yeah my vtec hits at 6k. the only time I can take my car past 6 is when I'm almost out of gas cus the vtec won't hit
Old May 13, 2011 | 01:33 PM
shelltodreamda9's Avatar
get a multi meter and test ur tps sensor. should read 5.0
happen to my non vtech n wouldnt go past 4k n bogged out weird ... idk if that tha same problem but maybe,,
Old May 13, 2011 | 02:06 PM
hyracer's Avatar
Tps is fine
Old May 14, 2011 | 01:30 AM
hyracer's Avatar
Somebody told me its bad spark plugs. But if the plugs are bad shouldn't it run bad throughout the whole rpm range. Mine runs fine. I disconnected my vtec and it ran fine all the way to 8k but cel came on so I reconnected it. Still stops right at vtec.
Old May 14, 2011 | 09:01 AM
el crapitan's Avatar
could be the solenoid. have you checked for codes? i would disconnect the battery ground to clear the codes. drive it for a day or so, then check codes
Old May 14, 2011 | 09:13 AM
94VTEC2TONE's Avatar
i highly doubt it will read 5.0 more like 4.5 or so. some systems when they see 0 or 5.0 they throw the code for outside limits, idk if tegs will. Just ign off sweep the throttle and check results
Old May 16, 2011 | 02:13 AM
hyracer's Avatar
if it was the solenoid the vtec wouldt even crack right? vtec cracks. the solenoid should be fine...
Old May 16, 2011 | 07:27 AM
Hollywood*'s Avatar
I had this problem with my jdm gsr....it wouldnt let me rev higher then 3500k....I was running a chipped p28, put in my virgin p28 and it ran fine....maybe try that...
Old May 16, 2011 | 07:32 AM
h2b_itr's Avatar
i would check your ecu, try to re burn the tune. I had the same problem with my old built type r, after re burning it did fine. Or maybe i just got lucky.
Old May 16, 2011 | 01:05 PM
hyracer's Avatar
i tried a few different ecus....i just re chipped mine...still the same problem...im stumped
Old May 17, 2011 | 11:49 PM
hyracer's Avatar
I just tried my friends stock gsr ecu and a jun ecu...still the same problem
Old May 18, 2011 | 05:28 PM
DISFORCFC's Avatar
I have a Redline issue too
Old May 19, 2011 | 07:10 PM
JoHnnY LonGHoRn's Avatar
Are u using a usdm ecu ? Sounds like the knock sensor cutting fuel. ? Correct me if I'm wrong
Old May 20, 2011 | 09:39 AM
i would like to rephrase my last post it should read 5.0 when you hold the throotle all the way open..
but like you said its probly not that anyway .. this is just what i meant to say last time... goood luck with tht ..
Old May 20, 2011 | 12:59 PM
hyracer's Avatar
im using a p28 ecu...when i got it re chipped i deleated the o2 sensor knock sensor and some other things...its not the ecu...i tried stock ecus and a bunch of different chipped ecus....
Old May 23, 2011 | 02:27 PM
hyracer's Avatar
you think maybe my whole harness could be messed up?
Old May 24, 2011 | 02:06 PM
Alvi84's Avatar
I'd check the distributor. Sounds like a weak coil. It has enough to start your car but not enough to rev high.
Old May 24, 2011 | 02:10 PM
wunfstgsr's Avatar
Loved
Community Favorite
try a diffrent dist. and also take out the vtec solinoid and clean it out and replace the vtec solinoid screens it might be dirty. My ITR hits vtec at 6k also so thats not the problem for you, are you sure your oil level is good, keep it at the top hole on the dip stick not the middle so you have a good amount of oil. maybe your oil pump may be failing but iv never heard it to go bad and cause no vtec.
Old May 24, 2011 | 04:03 PM
hyracer's Avatar
My distributer is fine..when I disconnect the vtec I can rev high all I want...the vtec solenoid is fine its clean and the screen is not clogged...and the oil level is fine too
Old May 24, 2011 | 06:48 PM
wunfstgsr's Avatar
Loved
Community Favorite
i believe its the vtec solinoid did you try another one yet?
Old May 25, 2011 | 11:52 AM
hyracer's Avatar
i talked to a lot of people and they said the vtec solenoid should be fine...cus the vtec actually cracks before the rpms stop...and the check engine light should come on if its not working properly
Old May 25, 2011 | 02:43 PM
Tha_liks's Avatar
maybe you have a locked Vtec Cam rocker lob preventing the Vtec lobs to kick in
