Pounded out Hub, No C-Clip there?
I recently pounded out my hub and bearing and was getting ready to press a new one in, but there wasn't a 73 mm retaining clip behind the hub holding the bearing in?
Is this mandatory or can I get by without it since the hub nut technically holds it on?
Honda wants 8 bucks for one and they might have to order it and my Vx being down is killing my pockets, my other car only gets 20 mpgs and I'm a delivery driver lol.
Also tried to change my torque mount and that was a mistake. One nut that is welded inside the frame busted free now the bolt just spins, and the other bolt head is rounded from corrosion. I heard cutting it off and welding it on might cause it to fail because of the heat? Or should i just cut an access panel and use two locknuts with some shorter grade 8 bolts?
This car is a damn rust bucket! Lol. Any help would be great.
I'm thinking about just driving it for now with one bolt holding the toque mount on until I can pull the bumper off and cut an access panel. Then I can use a box wrench and a locknut to reattach it after I cut it off and pop the other weld free on the one that is rounded off.
This same **** happened to me on my trailing arm bushing. A damn weld popped on one of those bolts. Luckily it is the side that has two. I know of a good welding shop so I might just come at them with my problems and see what they can do. I'm dreading the rear suspension because I had the same problems on my Del Sol and it wasn't near this rusty.
xtremsiege2
Apr 1, 2011 09:21 PM
CRX7
Mar 17, 2002 01:44 PM
