Intake swap need some help Thanks
Ok Im not trying to bring up an old post I have looked and found nothing on this but I bought a jdm d15b obd1 and the injector plugs are the same as my d16y7 obd2 the d15b head is a P2A yr 96 and the d16y7 head is a P2F-HA-5 yr is 99 but in a 2000EK. From what I was also told the clips should be different so some help on this would be cool Im trying to do a intake swap and just dont know if the injectors are the same I also swaped the map sensor idle air control valve. Dose the tps have to be swaped as well they both have a # of jt3L any info would be cool thanks.
Both sets of injectors are reading 10.5 ohms and plugs are the same some infor would be cool on this.
